| Help Forum Have a question that needs answering? Got the bike stripped, and can't remember how to get it back together? This is the place for you. |
Thread Tools |
#1 |
Baby Twin
Member: 15635
Last Online: 08-06-2010 04:27 PM
Trader Rating: (0),(0%)
help please
hi, i bought a 98 tl1000r that has been standing a while, it takes a while to start and then it stalls,
: its ok if i ride it straight away, but when i pull up it stalls, apparantly its had new spark plugs. Theres no error code displayed apart from check oil which i will sort out, the fi light goes off when the engine is running, please has anyone got any ideas because im getting it mot'd tommorrow. What is normal engine temp, could this be the prob, any help will be greatly appreciated, thanks in advance![]() |
#2 |
Baby Twin
Member: 15635
Re: help please
hi, i was wondering if someone could help me, i took my bike to the bike shop , to get the throttle bodies sorted, and they are having problems with the rear cylinder, doesnt matter what they do, it doesnt make a difference, it wont balance and keeps coughing and spluttering, please can some one help!!!
#3 | |
The Great And Powerful
Member: 2769
Last Online: Yesterday 07:34 AM
Bikes: 98 TL 1000-R
Trader Rating: (1),(100%)
Re: help please
Quote:
You should ask if the throttle bodies are properly seated. Hopefully they have checked for vacuum leaks. You might want to download the manually or have the mechanic do it, as there could have been a modification to the bike that you don't know about. I know I have personally spent time at a stealership teaching their technicians about my bike, that disease is cured here on The Planet - good luck.K
__________________
"Owning the ultimate driving machine, Does not make you the ultimate driver" PCII, Full M4 exhaust, Joe V Mod, Ivan's TRE, Top Gun Undertail, Pazzo levers, Fan & Headlight switch, Vandriver's TailRaisers & P.P., brake reservoir, MotoWerx clutch cover,YTZ14S battery, Rifelman's throttle insert, Full Bitubo supension, LED signal mirrors, Chucks headlight mod, Nobunaka rearsets, ss brake lines. Wish list: Vandriver's Tripple Clamp! |
#4 |
Junior Member
Member: 12166
Last Online: Yesterday 06:19 AM
Bikes: 98 TLR
Trader Rating: (2),(100%)
Re: help please
SV coils/new fuel filter and plugs and take the left fairing off and clean the yellow connector near the headlight (main harness) and the connector near the battery with the fuse in it.
#5 |
Baby Twin
Member: 15635
Re: help please
hi, thanks for the response, i will try these tomoorw when i go to the bike shop, i was also wondering if having race cans on and not been set up for them could cause these problems, and if putting the standard cans back on would help. also could bad petrol do this?, thanks im desperate to start riding this bike lol.
#6 |
Evil Twin
Member: 8893
Last Online: 09-08-2010 07:10 AM
Bikes: BLACK2KTL1000R
Trader Rating: (3),(100%)
Re: help please
i am assuming you put it in dealer mode and figured out the codes, right? if you don't know how to do this, search. It is all over the site. Also the yellow link on the top menu has tones of information you can take to your shop. Best of luck. Doesn't sound terminal. peace.
#7 |
Baby Twin
Member: 15635
Re: help please
hi, i put the bike in dealer mode and didnt get any error code according to the dash there are no problems, i changed the spark plugs over when i had everything off , the bloke that had it before me, put the wrong plugs in it, i put new sparks in it and it started and sounded better, i put the standard cans on and it started and idled, i repaired the connection on the tre, then put everything back together, now its running v rich, wont start, stinks of petrol, still no error code,is it because i put the standard cans on, or is it something to do with the tre (which i wouldnt of thought so) any ideas of what has made it do this, i was hoping it was fixed then now this. help!!!, thanks.
#8 |
Rizla Twin
Member: 14771
Last Online: Today 01:25 PM
Bikes: 97 Rizla TLS
Re: help please
Have the dealership set the TPS and sync'd the throttle bodies for you?
Double check the routing of the vacuum hoses. very easy to get it mixed up. |
#9 |
Baby Twin
Member: 15635
Re: help please
hi, thanks, i will get them to check the vacuum pipes, they have done the throttle bodies, i will get them to do the tps, so it has nothing to do with the tre and putting the standard cans back on, i was really looking forward to having a blast on it as well
see if this works i ve had to butcher the phot to get it to the right size but thats my bike til it needed a respray lol |
#10 |
Evil Twin
Member: 8893
Re: help please
in your description, you state everything going good until you "corrected" the TRE. Maybe I missed it but you didn't state you had a TRE. so best of luck...
#13 |
Member
Member: 15589
Last Online: Today 02:22 PM
Bikes: 2000 TL1000R
Re: help please
As far as TRE, I have no ideas, but my mechanic had stated that they have to get mapped to the bike......oh, they may be the power commander he mentioned, after I asked him about the advantage of a TRE.
I'll shut up now. |
| Thread Tools | |
