| TLS / TLR Main Forum Main forum for the discussion of the TL1000S and TL1000R. |
Thread Tools |
#1 |
One Liter Duc Eater
Member: 3415
Last Online: 07-17-2007 10:02 AM
Bikes: TL1000R 1998
Trader Rating: (12),(100%)
Compatible Parts List Database?
Can we make one. i hate to search a million threads for 1 thing. Like a front fender, calipers. forks etc. can we make a list? excel? web? something....
#2 |
One Liter Duc Eater
Member: 2639
Last Online: 07-10-2007 06:27 AM
Bikes: TLS1000
Trader Rating: (33),(100%)
Sounds good. Locate the threads and we might be able to put something together. Who here knows .net or Access to create a database with the parts, part descriptions, other hardware needed for swap/mod etc. Pop in some queries to help in searching would be nice.
#3 |
One Liter Duc Eater
Member: 3415
Bikes: TL1000R 1998
Nice.. ok guys lets start it cracking
__________________
![]() Visit http://www.fibercustoms.com for the latest products And Soon to come http://www.fullthrottleplastics.com http://www.carbon-custom.com |
#4 |
One Liter Duc Eater
Member: 3415
Bikes: TL1000R 1998
so far this is what my hours worth of searching found
Brake lever: 89-04 GS500 92-93 GSXR600 97-00 GSXR600 86-00 GSXR750 89-98 GSXR1100 99-00 GSX1300R 97-03 TL1000S 98-03 TL1000R 99-02 SV650/S Clutch lever: 89-04 GS500 86-00 GSXR750 89-98 GSXR1100 99-00 GSX1300R 97-03 TL1000S 99-02 SV650/S Rear Caliper: 2001-2002 Gsxr1000 No Modification Straight Bolt on "but... The banjo bolt is a different pitch for the GSXR caliper. Make sure if you get one that it comes with the bolt or if you’re running an aftermarket line that you’re able to get a new bolt for the caliper. Outside of that it bolts right up with no issues" -BurnCvycle 96-99 GSXR750 97-00 GSXR600's 2003-2004 Busa ZX9R (newer models) ZX12 (newer models)
__________________
#5 |
something wicked this way comes
Member: 13
Last Online: 08-15-2007 10:08 PM
Bikes: 2002 TL1000rr
Trader Rating: (40),(100%)
i was thinking the same thing
like forks rearsets wheels clip ons controls ect ect.
__________________
MY MODS: Ackrapovic Evo II full exhaust Head Work,Flowed injectors,Port /Polish exh and intake.cams,subframe,projector headlights,gap mod,Undertray,air/oil breather,pair valve removal,black frame Earth grounding mod . Dynojet PowercommanderII: (Custom Map by Orient Express):Galfer Wave Rotors Front & Rear: Pyramid Hugger:GSXR1k rear brake:A.T.R.E,Galfer Steel braided lines Front & Rear:TLS Cable Clutch Conversion:Woodcraft clipons:Vortex top triple clamp: DID Erv2 gold 520 conversion: Spocket Specialist Titan Tough Sprocket 17/41:GSXR tail: Nocut Frame Sliders:Air Tech Black Chrome Windscreen:LP Carbon Mirrors:Raised Tail 3/4" Ohlins Steering Damper:BRG 1/5 Throttle:GP Tech Fairing Bracket: Clear Alternative tail light:Black rims, ProTeck rearsets.gixxer 1k fender.Bitubo shock,custom projector headlights Race plastics and air tubes by AK composite 3/4 tail rasier custom made by TLDV8 Going For 440 wet weight.136 +HP. 72 +TQ TO BE CONTINUED |
#6 |
Member
Member: 3648
Last Online: 06-08-2005 07:05 PM
Bikes: 2000 tl1000s
Trader Rating: (1),(100%)
head light and kill switch and throttle tubes
2000-2003 gsxr-750 shift levers 2000-2003 gsxr-750 those i know first hand from having to swap
__________________
sparkkoT mod.frame sliders,carbon fiber rear hugger painted to bike,painted stock winshield,tre mod,k&n filter,woodcraft clip ons,lots of polished and powder coated bits.cut down m4 2into 1, |
#7 |
One Liter Duc Eater
Member: 2639
Bikes: TLS1000
I gave it some more thought. A searchable website would be better I think instead of Access or .net. You could still use these tools but it might be overkill. A searchable website would work just as good I think.
#8 |
EVIL TWIN SUPERBIKE
Member: 542
Last Online: 06-21-2008 08:52 PM
Bikes: 98' TLR & 98' TLR track bike
Trader Rating: (18),(100%)
Front fenders:
TLS = TLR 96-99 SRAD Gixxer HAYABUSA
__________________
2006 749 Ducati and a 1998 TLR-1000 track bike
#9 | |
woof woof
Member: 328
Last Online: 04-05-2010 02:37 PM
Trader Rating: (14),(100%)
Quote:
I don't remember about the throttle side. The brake light assembly (lens & reflector) is the same as the first gen (99-02) SV650/S and some GSXR's but I do not know which models/years.
__________________
Common sense is not very common. |
#10 |
One Liter Duc Eater
Member: 3415
Bikes: TL1000R 1998
Front Fender:
All TLS = TLR 96-99 SRAD Gixxer All HAYABUSA The brake light assembly (lens & reflector) 99-02 SV650/S first gen Brake lever: 89-04 GS500 92-93 GSXR600 97-00 GSXR600 86-00 GSXR750 89-98 GSXR1100 99-00 GSX1300R 97-03 TL1000S 98-03 TL1000R 99-02 SV650/S Clutch lever: 89-04 GS500 86-00 GSXR750 89-98 GSXR1100 99-00 GSX1300R 97-03 TL1000S 99-02 SV650/S Shift Levers 2000-2003 gsxr-750 Left Side Controls: 99-02 SV650/S first gen 00-03 gsxr-750 Rear Caliper: 2001-2002 Gsxr1000 No Modification Straight Bolt on "but... The banjo bolt is a different pitch for the GSXR caliper. Make sure if you get one that it comes with the bolt or if you’re running an aftermarket line that you’re able to get a new bolt for the caliper. Outside of that it bolts right up with no issues" -BurnCvycle 96-99 GSXR750 97-00 GSXR600's 2003-2004 Busa ZX9R (newer models) ZX12 (newer models) Come on guys lets add some more. Plus, if you add something, please specify what had to be done to add it. Modified? Straight fit etc. im going to make a small website for this. with contributed pics etc.
__________________
#11 |
Member
Member: 3648
Bikes: 2000 tl1000s
pegs
__________________
#12 |
Member
Member: 3648
Bikes: 2000 tl1000s
pegs off of busa's gixxers and sv's all work i know 2000+
__________________
#13 |
One Liter Duc Eater
Member: 1159
Last Online: 06-03-2009 07:30 PM
Bikes: 2001 TLR
Trader Rating: (36),(100%)
Front Fender:
All TLS = TLR 96-99 SRAD Gixxer All HAYABUSA Busa fenders are not the same, different mounting points.![]()
__________________
New Orleans, every ride at our Six Flags is a water ride.
#14 |
Do your nipples itch?
Member: 237
Last Online: 08-27-2010 10:57 AM
Bikes: 1997 TL1000S
Trader Rating: (3),(100%)
Front calipers all direct bolt-ons:
6 piston 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa 4 piston 97-00 GSXR600 TL1000S Mirrors: 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa 97-00 GSXR600 TL1000S Wheels fronts 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa 97-00 GSXR600 TL1000S 6.0" rears 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa TL1000S 5.5" rears with all spacers 97-00 GSXR600 Foot pegs 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa 97-00 GSXR600 TL1000S See the trend? |
#15 |
One Liter Duc Eater
Member: 3415
Bikes: TL1000R 1998
Ok people keep it coming.. make this list Grow!!! =)
Front Fender: All TLS = TLR 96-99 SRAD Gixxer All HAYABUSA The brake light assembly (lens & reflector) 99-02 SV650/S first gen Brake lever: 89-04 GS500 92-93 GSXR600 97-00 GSXR600 86-00 GSXR750 89-98 GSXR1100 99-00 GSX1300R 97-03 TL1000S 98-03 TL1000R 99-02 SV650/S Clutch lever: 89-04 GS500 86-00 GSXR750 89-98 GSXR1100 99-00 GSX1300R 97-03 TL1000S 99-02 SV650/S Shift Levers 2000-2003 gsxr-750 Left Side Controls: 99-02 SV650/S first gen 00-03 gsxr-750 Rear Caliper: 2001-2002 Gsxr1000 No Modification Straight Bolt on "but... The banjo bolt is a different pitch for the GSXR caliper. Make sure if you get one that it comes with the bolt or if you’re running an aftermarket line that you’re able to get a new bolt for the caliper. Outside of that it bolts right up with no issues" -BurnCvycle 96-99 GSXR750 97-00 GSXR600's 2003-2004 Busa ZX9R (newer models) ZX12 (newer models) Front calipers all direct bolt-ons: 6 piston 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa 4 piston 97-00 GSXR600 TL1000S Mirrors: 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa 97-00 GSXR600 TL1000S Wheels: fronts 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa 97-00 GSXR600 TL1000S 6.0" rears 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa TL1000S 5.5" rears with all spacers 97-00 GSXR600 Foot pegs 96-99 GSXR750 98-03 TL1000R 99-04 Hayabusa 97-00 GSXR600 TL1000S
__________________
#16 |
Evil Twin
Member: 880
Last Online: 10-25-2008 07:37 AM
Bikes: 97 tls 1000
Trader Rating: (1),(50%)
bump ...great idea.....but what is it saying..all the parts above fit any year TLR..TLS
![]() That would be more usefull....just a thought ![]()
__________________
Grab life by the balls ....... Not your buddies!!!!!! 97TLS/GapMod/PC2/Sparko Mod/Airbox Mod/Fan Switch/ Fresh Paint.................... |
#17 |
One Liter Duc Eater
Member: 3415
Bikes: TL1000R 1998
Yes when i was leaving work, i noticed we have to make a list for 2 bikes =) can somone split the list i have so far got together from tlp members?
__________________
#18 |
Stupidity SHITS ME!!
Member: 4493
Last Online: 05-17-2010 05:59 AM
Bikes: '98 TLR
Trader Rating: (15),(100%)
Bump...
How about pinning a list like this in frequent mods? ![]()
__________________
![]() Check out my store: RATEDR CUSTOM MOTORCYCLE PARTS '98 TLR, Yoshi Stainless Bolt-ons, Custum Metallic Purple Paint, Powder Coated Frame, Carbon Wrapped Tank, Clear Clutch Cover, Cable Clutch Conversion, Gold D.I.D 530 Chain, Vortex Sprockets(17/41), BMC Filter, Brisk Plugs, MotoMaster No-Cut Frame Sliders, TopGun UnderTail, Gixxer Carbon Front fender, Purple Iridium Screen and Headlight Cover, Gold Plated, Chromed & Polished Stuff, Gold OZ Racing Rims, Pirelli Diablo's, Galfer Wave Rotors Front & Back, TRE, Jarkko T "+" Mod, Fan Mod, Grounding Mod, Joe V AirBox Mod, Mini LED Turn Signals, LED UnderBody Kit, Stainless Brake Lines, Relocated Rear Brake Resevoir, Spiked Fairing Bolts, Spiked BarEnds, Spiked Spools, Flamed Chain Adjusters, Acumen Digital Gear Indicator, Raptor ShiftLite, Cheetah Alarm, Ducati Carbon Mirrors... Plenty more to come!!! |
#19 | |
F*ck Tucker, Tucker sucks
Member: 4915
Last Online: 11-14-2007 09:42 AM
Bikes: nada :(
Trader Rating: (4),(100%)
Quote:
#20 |
One Liter Duc Eater
Member: 1366
Last Online: 07-20-2010 12:45 PM
Bikes: TL1000S
I made a (German) spreadsheed that I'm willing to participate if anyone wants to use it:
http://www.mrufer.ch/motorrad/forum_...iche_teile.pdf Greetings Rufer
__________________
2x TL1000SW, candy jade lime yellow. TL1000cup.de champion 2007 & 2008 |
| Thread Tools | |
