| Motor Tear Down and Rebuild A complete resource for engine modifications and repair. |
Thread Tools |
#1 |
stretched,dropped,& sittin' on chrome
Member: 8752
Last Online: 09-03-2008 04:05 PM
Bikes: '02 TLR
Trader Rating: (0),(0%)
anyone know how to repair stripped oil plug pan? help!
hey guy i accidently stripped out my oil pan where the plug goes in, any ideas on a quick fix?
#2 |
Just tiny specs in the mirror...
Member: 4998
Last Online: Today 03:29 PM
Bikes: TLR Streetfighter, TLS Streetfighter, 1985 V65 Magna
Trader Rating: (28),(100%)
Re: anyone know how to repair stripped oil plug pan? help!
Wow that sucks.
Go to an auto parts store and buy a plug like the middle one in the pic below... ![]() |
#4 |
Member: 4998
Ask for a rubber oil plug with a wingnut
#5 |
Superbike Twin
Member: 7476
Last Online: 07-07-2010 10:58 AM
Bikes: 1997 TLS, 2000 TLR
Trader Rating: (5),(100%)
Auto parts stores usually have oversized drain plugs with self tapping threads (bring your old one in for reference)...
#6 |
The rider formerly known as chief_rawka
Member: 8697
Last Online: 05-08-2013 02:47 AM
Bikes: TLR 98 Fighter
Trader Rating: (14),(100%)
i used rubber and it sucks..... they have better options that re tap the hole try pep boys dbl size
#7 |
Member: 4998
I know the rubber plug is shitty...
The rubber plug is a fast option and if you get the right size it won't leak. Self tapping bolts cause metal in the pan... I think I would look into a compound like alumiloy to fill the hole, drill & retap. |
#8 |
Beware the penguins...
Member: 249
Last Online: Today 06:21 PM
Bikes: 1978 GS 1000E
Trader Rating: (11),(100%)
Use heavy grease on the threads of a self tapping bolt and it will catch the metal shavings. INstall the bolt, remove it an clean it up then reinstall and you're good to go. :thuimbup
__________________
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles." Colonel Jeff Cooper, in "The Art of the Rifle" |
#9 | |
Superbike Twin
Member: 7470
Last Online: 03-07-2008 02:08 PM
Trader Rating: (3),(100%)
Quote:
sorry for the hijack
__________________
![]() xtreme tlr race rads samco hoses brembo brake and clutch waveys 4 to 6" swingarm extenders chrome calipers pipercross filter full wp suspension blueflame cans and so much more MY WEB SITE. www.xtremeparts.co.uk http://www.bikepics.com/members/coolasice/98tlr/ Last edited by fostersice : 02-19-2007 at 04:20 AM. |
#10 |
Member: 8697
it looked just like the one on chuck pic, and it was the right size. i just leaked ever so slightly. the self tapping worked great though
#11 |
Member: 4998
Self tapper with grease sounds like a fix!
#13 | |
ditch the bitch, lets ride!
Member: 6275
Last Online: 12-13-2012 04:43 PM
Bikes: 2000 TLR,2001 VFR,2007 V-Strom, 1978 GS550, 2003 SV1000S
Trader Rating: (30),(100%)
Quote:
when this happened to me, that is EXACTLY what i watched my local wrench do to my bike. its been a year and never a leak since. this is the way to go for long term fix. the wingnut deal should work in a pickle but re tapping is the way.
__________________
![]() ->TL1000R<- |
#14 |
Baby Twin
Member: 7875
Last Online: 08-29-2008 05:53 AM
Bikes: 99 tlr1000
Trader Rating: (1),(100%)
DONT use the rubber plug i did and had a mess one day, when the bike got hot it fell out on me, i dont know if the rubber strunk or what, but what a mess. I went to the automotive store and they gaved me a self threaded bolt with another bolt in the middle, put locktite on the bigger bolt and use the small bolt to drain your oil, and never had a problem yet..
#15 |
Superbike Twin
Member: 8072
Last Online: 05-23-2012 07:49 AM
Bikes: 2001 TL1000R
Trader Rating: (2),(100%)
If you havent done a repair yet, it might be a good idea to check a heli-coil set.
there is room to tap this out ( with alot of grease on tap ) and then insert the stainless threads in it, you can use a 1/2" breaker bar and it wont strip again, if there is all the fairing stuff out of the way it is normally a $40.00 repair that we charge, also be sure to change your filter..........
__________________
wWhere ever there is sin, thats where i shall ride!!!!! |
#16 |
Yeah I'm a Noob
Member: 8828
Last Online: 10-25-2007 11:09 PM
Bikes: 2003 TL1000R
noooooooo! dont use a helicoil i had a bad experience with those. the bolt that held my alternator in place on my 350 somehow stripped the threads out on my head (how the hell that happened i still dont understand) and someone recommended helicoil to me. I tried it and it failed. It just ended up stripping it out bigger. Luckily the heads on a 350 are reversible if you swap them over and turn them around so basically i had to do a top end rebuild because of a stupid bolt.........Anyways, I would go witht the self tapping bolt.
#17 |
Member: 249
medrick, helicoils are a good product. It wasn't the helicoil that failed, it was the user.
__________________
#18 |
Superbike Twin
Member: 9485
Last Online: 01-06-2013 06:31 AM
Bikes: 02 TLR
Ifin yer sufferin' about the chips when runnin' in the tap from the bottom put your hose in your mouth an' blo....crank breather hose thatis ....
#20 |
Junior Member
Member: 10961
Last Online: 08-30-2010 03:21 AM
Bikes: 2000 TLS
I just dealt with this. Bought bike used, first thing i did was change the oil and all the threads came out.
Had recommend against Helicoil because of the aluminum block. I think the plug is 14mm 1.25 threads, I purchased oversized 14mm 1.5 thread self tapping, lay the bike on its side, make sure you are square and slowly tap that bitch in. Works great |
| Thread Tools | |
