| TLS / TLR Main Forum Main forum for the discussion of the TL1000S and TL1000R. |
Thread Tools |
#1 |
member
Member: 14002
Last Online: Yesterday 10:45 PM
Trader Rating: (3),(100%)
Busa forks
wondering what would be the advantages putting busa forks on the TLR, what mods would have to be done and what year would fit.Thanks
#2 | |
Baby Twin
Member: 14445
Last Online: 08-25-2010 12:46 PM
Bikes: '98 BL&WT TL1000R
Re: Busa forks
Quote:
#3 |
...just pay the $10
Member: 13182
Last Online: Today 03:01 PM
Bikes: Ducati M750 2K1, SV650S 2K5, TL1000R 2K3, Aprilia RS50 2K1
Trader Rating: (6),(100%)
Re: Busa forks
The lowers are Ti-nitride coated for smoother operation. Internals are the same. 99-07 are direct swaps.
Brakes are good swaps too, same years. Look for the star (torx) bolts to get the aluminum pistons, rather than steel pistions (allen).
__________________
You do not talk about Fight Club.... 2003 TL1000R Y/B - Full M4 system with D&D bolt-ons, HyperPro RSC, Ohlins rear, Revolution Rotors, Danos TRE, Pipercross, Airbox mod, 195 fan switch ('94 civic), PAIR removed, 41T SuperSprox, LED lights, Yosh'd +5+10+5, Zero Gravity Smoked, Goodridge lines, Pilot Road 2CT, Van's reservoirs, Pazzo Levers, Gilles Rearsets, HK Chain Adjusters, Bestem Undertail, Ducati fender eliminator, gap mod, Coerce fenders, Yosh stem nut |
#4 |
Maximum warp!
Member: 553
Last Online: Yesterday 10:09 AM
Bikes: 2000 TLR (yellow)
Trader Rating: (13),(100%)
Re: Busa forks
I think the internals are a bit sturdier. Sean (speedking) knows all about them. They are also longer than the TLR forks so you need to drop the triple a bit more to maintain the proper steering geometry.
__________________
#5 |
One Liter Duc Eater
Member: 3727
Last Online: Today 06:16 PM
Trader Rating: (176),(100%)
Re: Busa forks
Now that there is a second gen. of Busa's, saying Busa forks is like saying GSXR forks. Too many possibilities.
#6 |
Evil Twin
Member: 15108
Last Online: Today 01:20 PM
Bikes: 98 B/w TLR
Re: Busa forks
Actually I don't think much of this is truth. The 1st gen busa forks have softer springs then the tlr, I am pretty sure the valving is a little plusher ( but you would need a suspension builder to tell as I can't tell) and the forks are around the same length ( Sam has a fork chart if you wanna know for sure whats what). The drop outs are slightly different so you cant cross genders without modifiying. Also, the tlr internals will drop right in the busa forks.
#7 |
member
Member: 14002
Re: Busa forks
I guess the question was a little vague, I will try again...
What year busa forks would fit on a TLR and what mods would have to be done if any. |
#8 |
Maximum warp!
Member: 553
Re: Busa forks
Mine are 05 busa forks, you can see the difference in length.
![]() The factory valving and spring rates are softer, but the internals are slightly more substantial (beefier) IIRC from speedking's analysis. The dropouts will need to be modified to fit a TLR fender.
__________________
#9 |
Evil Twin
Member: 15108
Bikes: 98 B/w TLR
Re: Busa forks
Almost any info you need will be in this thread....tlplanet.com/forums/showthread.php?t=78678&highlight=fork+chart
The busa forks, you can use your triples, your brakes etc. But Need to use a busa fender or mod the dropouts to use the TL one. |
| Thread Tools | |
