TLPlanet Forums
Go Back   TLPlanet Forums > Main Forums > TLS / TLR Main Forum
Register FAQ Members Bike Gallery Mark Forums Read
TLS / TLR Main Forum Main forum for the discussion of the TL1000S and TL1000R.
Reply
Thread Tools
Old 04-18-2012, 09:25 AM   #1
Brainless
Expert crasher
Brainless's Avatar
Member: 1869
Last Online: Today 06:12 AM
Bikes: 2002/2000/1998 TL1000R - 1997 RF900RV
Trader Rating: (72),(100%)
Mini-ATM fuse block
I've been searching all over and can't seem to find something descent and affordable:
I'm looking for an small/compact Mini-ATM fuse block, preferably 6 fuses. This is the closest thing I can find but I think it's still too big:
What have you used?
__________________
Brainless AT earthling DOT net
"Take 2 plugs off your Gixxer and it'll sound the same"
*IMWO = In My Worthless Opinion
Q2's Gallery and Mod list
History of Q2
Q4's Gallery and Mod list
Q4 build thread
Installing Brainless' +Mod Kit -- (Where to buy)
Starter Relay/Solenoid CONNECTOR Replacement -- (Where to buy)
Brainless is online now   To the Top of Page Reply With Quote
Old 04-18-2012, 11:00 AM   #2
Crazyfamily
One Liter Duc Eater
Crazyfamily's Avatar
Member: 10513
Last Online: Today 12:51 AM
Trader Rating: (15),(100%)
Re: Mini-ATM fuse block
whatcha using it for?
Crazyfamily is offline   To the Top of Page Reply With Quote
Old 04-18-2012, 11:03 AM   #3
Brainless
Expert crasher
Brainless's Avatar
Member: 1869
I'll be re-routing all my mods to the fuse block.
+ mod
Projector headlights
Charging system
(soon) air horns
__________________
History of Q2
Q4 build thread
Old 04-18-2012, 11:39 AM   #4
JDBeck23
Evil Twin
JDBeck23's Avatar
Member: 8976
Last Online: 12-31-2013 02:32 PM
Bikes: 2000 TLR, Blue and White
Trader Rating: (5),(100%)
JD,
Eastern Beaver has a small 3 circuit Mini ATM fuse block. I bought it for the exact same reason. I am in the throws of +mod and charging system mods right now.
I dont like adding alot of inline fuses either, but I doubt you'll find one that's as small as you want it.
I have used a Painless Fuse Block with 4 fuses in the past, it has a cover that you can buy separately. For 10 bucks you cant beat it for the size.
They have alot of universal kits as well, same 4 fuse block, snapped together as a pair with a one or two relays that you can use to power the block. Alot of adjustability. Go to summittracing.com and search for painless universal and you'll get alot of options.
__________________
2000 TLR, M4 Full System w/ shortened cans, BMC Air Filter, Airbox mod, PCIII, Ohlins Shock, 08 Busa Front End, Scotts Steering Damper, 09 GSXR Rear Wheel, 520 Conversion, R/R Upgrade, Headlight Wiring mod, +mod, gap mod, GSXR clocks, JoE Converter...
JDBeck23 is offline   To the Top of Page Reply With Quote
Old 04-18-2012, 11:52 AM   #5
Brainless
Expert crasher
Brainless's Avatar
Member: 1869
I saw EB's and it's doing a lot more that I want it to do. I'm considering buying that as a last resort if I can't find one that fits my needs.
The EB's, IIRC, only has 2 hot fuses. The others are ignition controlled, or something like that.
__________________
History of Q2
Q4 build thread
Old 04-18-2012, 11:59 AM   #6
JDBeck23
Evil Twin
JDBeck23's Avatar
Member: 8976
You're right, but that's if you buy it in kit form...
I bought just the fuse block, that way you can wire it up however the hell you want!
Since you have a million feet of wire, you just need the fuse block anyway!
__________________
Old 04-18-2012, 12:22 PM   #7
Brainless
Expert crasher
Brainless's Avatar
Member: 1869
Hmm... didn't know you could just buy the box...
But I think I found one that might work:
Here
__________________
History of Q2
Q4 build thread
Old 04-18-2012, 12:32 PM   #8
fredycruger
Superbike Twin
fredycruger's Avatar
Member: 17199
Last Online: 10-07-2014 06:16 AM
Trader Rating: (11),(100%)
dont know about dimension but i found couple sites but you probably went trough them
http://www.autodax.com/SearchResults...&Submit=Search
http://www.autodax.com/product_p/20106mt.htm
http://www.cyclenutz.com/Fuzeblock-F...FZ-1_p_92.html
fredycruger is offline   To the Top of Page Reply With Quote
Old 04-18-2012, 12:38 PM   #9
fredycruger
Superbike Twin
Member: 17199
http://www.cyclenutz.com/Fuse-Panel-Relays_c_38.html
Old 04-18-2012, 01:40 PM   #10
JDBeck23
Evil Twin
JDBeck23's Avatar
Member: 8976
Here
That's going to take up a lot more room than you think with the pins being on both sides of the block. You'll have to route wires around to both sides, also exposing them to moisture because they are horizontal.
Check out the Painless block... actual terminals and they're vertical, and with the cover, no worries about water getting in.
__________________
Old 04-18-2012, 01:48 PM   #11
Brainless
Expert crasher
Brainless's Avatar
Member: 1869
I actually have 3 of those and they are ATC fuses, and not the mini-ATC. That thing is HUGE! ("What she said!") I can't use it.
__________________
History of Q2
Q4 build thread
Old 04-18-2012, 01:52 PM   #12
JDBeck23
Evil Twin
JDBeck23's Avatar
Member: 8976
Ah shit, you're right, my bad!
__________________
Old 04-19-2012, 11:50 AM   #13
tlrpunk
Maximum warp!
tlrpunk's Avatar
Member: 553
Last Online: Yesterday 05:04 PM
Bikes: 2000 TLR (yellow)
Trader Rating: (14),(100%)
Most of these are probably too expensive or too big for what you want. I've been searching as well, to no avail. I'll probably settle on the EB or the Blue Sea, maybe the Centec AP-1. I'm still not ready to pull the trigger yet.
__________________
tlrpunk is offline   To the Top of Page Reply With Quote
Old 04-19-2012, 11:56 AM   #14
Brainless
Expert crasher
Brainless's Avatar
Member: 1869
Quote:
Well, hold your breath a little more. I'm getting the one I mentioned earlier soon. I'll let you know.
__________________
History of Q2
Q4 build thread
Old 11-04-2013, 10:20 AM   #15
Brainless
Expert crasher
Brainless's Avatar
Member: 1869
Reviving this thread for further info
[snip]
Well, come to find out, I've been using those fuse blocks as there are no adequate Mini fuse blocks I could find. It's been a year and they've been working pretty good on 2 TLR's.
I found a similar block but seems to be a little better built, a little more compact and with a cover:
Hella brand.
As a comparison to the previous, both are 4-fuse holders:
I'll be switching to them as I go along with the projects this winter.
To get those fuse blocks, look up whose part numbers:
Part No.:
4-Gang Fuse Box - Bottom Tab Connections H84960061
6-Gang Fuse Box - Bottom Tab Connections H84960081
8-Gang Fuse Box - Bottom Tab Connections H84960101
__________________
History of Q2
Q4 build thread
Old 11-04-2013, 11:03 AM   #16
drH
Starting grumpy training soon
drH's Avatar
Member: 12682
Last Online: Today 04:27 AM
Bikes: '98 TL1000R fighter, 2002 TL1000R
hee hee hee your rotary damper is showing
__________________
Run over on: '98 TL1000S
Riding: '98 TL1000R fighter
Drooling over: '02 TL1000R
drH is offline   To the Top of Page Reply With Quote
Old 11-04-2013, 11:37 AM   #17
Jonstorp
Evil Twin
Jonstorp's Avatar
Member: 16959
Last Online: Today 01:22 AM
Bikes: Suzuki TL1000S 1997
Trader Rating: (3),(100%)
Hella brand.
Part No.:
Question: When you wire that block up, do you use one +wire to each fuse or one giant one and split it?
__________________
TL1000S -97
Bitubo rear shock, custom undertail, highpipes, hugger, Barnett clutchsprings, Airbox mod, K&N airfilter, Inline fuelfilter mod, thermostat mod, +mod, charging mod, IVAN'S TRE, headlight relay mod, Speedohealer, TLR front calipers, TLR Brake M/C with Goodridge lines.
Jonstorp is offline   To the Top of Page Reply With Quote
Old 11-04-2013, 11:49 AM   #18
Brainless
Expert crasher
Brainless's Avatar
Member: 1869
Quote:
I wouldn't recommend a "giant one" then split it. The new one will require me to feed one, then the next one, etc ("jumping" one to the other). Much more manageable in a tight setting.
__________________
History of Q2
Q4 build thread
Old 11-04-2013, 01:17 PM   #19
The Ring-In
arse'ole
The Ring-In's Avatar
Member: 13927
Last Online: Today 03:18 AM
Bikes: tl1000s naked
Trader Rating: (23),(100%)
I have a 6 slot like the first one you pictured
Its in the hiace . quite compact I bent the legs over on one side and soldered a 'busbar" wire down that side
bend the other side over to 30degrees for amore room
jaycar in oz $13 approx
The Ring-In is offline   To the Top of Page Reply With Quote
Old 11-04-2013, 02:29 PM   #20
Jonstorp
Evil Twin
Jonstorp's Avatar
Member: 16959
After google-ing "busbar" i get the idea.. One wire connected to all connectors.. Gonna install a fusebox when its time for charging and headlight mods.. Thanks!
__________________
TL1000S -97
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Copyright 2003-2010 InterweberNet, LLC
