TLPlanet Forums
Go Back   TLPlanet Forums > Main Forums > TLS / TLR Main Forum
Register FAQ Members Bike Gallery Mark Forums Read
TLS / TLR Main Forum Main forum for the discussion of the TL1000S and TL1000R.
Reply
Thread Tools
Old 11-13-2012, 09:36 AM   #1
bjohn07
Evil Twin
bjohn07's Avatar
Member: 18425
Last Online: 09-12-2014 06:22 PM
Bikes: 08 nightster/97 tl1000s
Trader Rating: (6),(100%)
air box mod worth it on tl1000s
i got a 97 tl1000s. just thinking of more mods i can do to it while its cold.
so how beneficial is the removing the flapper from the airbox mod.
just trying to see if the benefits are worth the work. if gains dont exceed at least 8hp or ft lbs i dont see myself doing it at all since im not gonna be taking this bike to the track.
bjohn07 is offline   To the Top of Page Reply With Quote
Old 11-13-2012, 10:35 AM   #2
twin2
Member
twin2's Avatar
Member: 9227
Last Online: Today 12:00 PM
Bikes: 97 tl1000s
Trader Rating: (0),(0%)
Re: air box mod worth it on tl1000s
I don't know about the others but for me the gaines where not hp but rather a smoother and more normal shifting ''less on-off jurking at small thottle opening''.
But that's me.
twin2 is offline   To the Top of Page Reply With Quote
Old 11-13-2012, 11:25 AM   #3
bjohn07
Evil Twin
bjohn07's Avatar
Member: 18425
Hmm. If mine has the jerking problem i dnt notice. Been doing some searchin on it and looks like everyones gains are different. Might have to leave it alone for now.
Old 11-13-2012, 12:09 PM   #4
Metalbender
One Liter Duc Eater
Metalbender's Avatar
Member: 16674
Last Online: Today 04:05 PM
Bikes: 97 TL 1000 S
Trader Rating: (30),(100%)
I did mine in expectation of what's to come in the future...the more air you can get into and out of a engine the more horses it will make...which is why I also got a fullset and k&n airfilter...
Metalbender is offline   To the Top of Page Reply With Quote
Old 11-13-2012, 12:54 PM   #5
gaztl1000r
proud tyke
gaztl1000r's Avatar
Member: 1533
Last Online: 07-01-2014 09:05 PM
Bikes: suzuki tl1000r till 2005 now running a tl1000s
Pick up a spare airbox and do the mod, that's what I've done, it'll be going in the rebuilt bike
gaztl1000r is offline   To the Top of Page Reply With Quote
Old 11-13-2012, 01:43 PM   #6
The Ring-In
arse'ole
The Ring-In's Avatar
Member: 13927
Last Online: Today 01:23 PM
Bikes: tl1000s naked
Trader Rating: (23),(100%)
http://www.tlzone.net/forums/bike-pi...ml#post1705683
BTW its very unlikely a K&N will flow better than a factory element
its just reusable
The Ring-In is offline   To the Top of Page Reply With Quote
Old 11-13-2012, 01:54 PM   #7
bjohn07
Evil Twin
bjohn07's Avatar
Member: 18425
This bike had a k&n already.
Old 11-13-2012, 02:15 PM   #8
gaztl1000r
proud tyke
gaztl1000r's Avatar
Member: 1533
Having had a few bikes with forced air induction, when you look at the tls airbox it surprising how well it runs considering the poor design,and relatively small size, so anything that improves the airflow has got to be an improvement,
If your unsure, just get a pen and paper and draw the flow of air, far too many turns and too much turbulence in the airbox
Old 11-13-2012, 03:46 PM   #9
bjohn07
Evil Twin
bjohn07's Avatar
Member: 18425
well just pulled the air box out. so do i need to completely remove the flapper or can it just be gutted and the housing left in place to fill the hole?
Old 11-13-2012, 04:17 PM   #10
bjohn07
Evil Twin
bjohn07's Avatar
Member: 18425
got a better look at it. all i did was remove the plastic flapper, pull out the actuator valve, cut the thin rod with the hook on the end that control the flapper. and put the actuator housing back in to cover the hole and plugged the vacuum line that connected to it. man that was way to easy. i thought it would have took me longer than 15 min. which is why i was hesitant about doing it.
Old 11-13-2012, 06:53 PM   #11
Big Red
Superbike Twin
Big Red's Avatar
Member: 7586
Last Online: Today 11:21 AM
Bikes: TL 1000 S
Trader Rating: (4),(100%)
Go to SteveTLS page and get the run down on what you need to do .It's fairly easy and "I think " a worthwhile mod .
I just used a bit of aluminium ,silicon ,and a dremel .
Big Red is offline   To the Top of Page Reply With Quote
Old 11-14-2012, 01:32 AM   #12
gaztl1000r
proud tyke
gaztl1000r's Avatar
Member: 1533
http://wotid.com/tls/component/optio...per/Itemid,38/
Enjoy the read
Old 11-16-2012, 12:29 PM   #13
cyclecamper
One Liter Duc Eater
cyclecamper's Avatar
Member: 4340
Last Online: Today 03:05 PM
Bikes: 2001 TLR, Cagiva 650, K1200LT
Trader Rating: (20),(100%)
You should do a lot more to get much benefit. The cross-over intake on one side is very restrictive, if you plastic-weld on an exterior flange and lace it up with some safety wire you can flow much more. You need to remove the transfer port that the flapper was in, at a minimum. You should remove the actuator and saw out the entire area, and plastic-weld in a larger curved cover over that area. Then consider cutting open the entire area between the lower and upper boxes, which then requires a new filter arrangement. On a stock '97 with an exhaust system I figure I got several hp, but mostly I got a lovely intake growl and much better throttle response. Good luck. Remember the flapper and transfer ports surrounding it is mostly a noise-reduction system. The TLS airbox ideally needs ot be much bigger and flow much more air with fewer restrictions and turns.
__________________
cyclecamper is offline   To the Top of Page Reply With Quote
Old 11-18-2012, 08:27 PM   #14
zippytlsr
One Liter Duc Eater
zippytlsr's Avatar
Member: 2058
Last Online: 08-02-2014 05:26 AM
Trader Rating: (19),(100%)
I noticed better throttle response around town and out on the road. Thought it was a worthwhile mod.
zippytlsr is offline   To the Top of Page Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Copyright 2003-2010 InterweberNet, LLC
