Nate
*click* during moderate/hard braking
I've noticed a single click coming from my front end during the last few yards of a moderate to hard brake. It's a 2000 tlr with no modifications to the front end and about 7500 miles on it. It's done this for as long as I can remember and it doesn't seem to affect performance, it's just disturbing. Any Ideas?
NateTags: None
I get it occasionaly on my S too. I just stopped looking for it in the end.
It's not something dumb on your bike like a wiring loom hitting something, or a brake line slapping something?"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
More than likely it steering head bearings.
It can't be the brake rotors, because once you're on the brakes, any "float" is already taken out of the rotors, so there's nothing there that's going to make any noise.
If you hold the front brake on (motor off so you can hear better) and quickly rock the bike forward (like you're trying to compress the forks) you'll probably get the same click, right at the point of most fork compression. If you do, then it's definitely your steering head bearings.
Good luck.
Jim Miller
Appalachian Signs & Graphics
* For All Your Sportbike And Racing Decal Needs *
Phone: 717-979-2814
www.appalachian-signs.com
[email protected]
My TLS does it too, but here's what I noticed ... I've got aftermarket pads on the front (DP HH+ I think). I'll roll by bike backwards out of the garage and down the driveway (slope), and use the front brake to slow the bike, making the pads shift in the wrong direction ... once I fire up the bike and start moving forward, the first time I brake, I'll here the click, the pads shifting forwards. They do it once, and no more (unless I roll the bike backwards and brake).
Your problem sounds a little different than mine, bob. I'd believe the floating rotor explanation for your bike. Mine happens just about every time I brake, though. And it's not just as the fork compresses or just as I apply the brakes, it's about 2 - 3 feet before I actually stop.I appreciate the input, though. I'm about to slap on some galfer pads and ss lines in the front. If that changes anything I'll post an update.
Originally posted by tlrpunk
Thanks for all the help! Should I replace the head bearings, then? Or is it something I can just ignore.
Jim Miller
Phone: 717-979-2814
[email protected]
I'd have to disagree with the steering head bearings if it's like mine. I'll put constant brake pressure on and then just before the bike stops moving, I hear/feel the click. No change in pressure so as far as I'm concened it's not the bearings. Doing the "push bike and hit brakes" test produces nothing as would the bearings so.... I've accepted it now but will also update any changes when I do SS lines and HH pads in the near future.1
I got the same results with the push and brake test, coyo...nothing. It sounds like we're in the same boat. You described the problem i've got perfectly. I'll keep my eyes open when I swap out my brake lines/pads, too. Lemme know if you find something. And thanks again everyone!
Nate
