graves fairing bracket
I"m thinking about removing the stock headlight and the stock fairing bracket, mainly for weight. Now, I know that I won't have any lights, but I never ride the TLR at nite anyway. If I want to ride at nite, I have 4 other machines to do so. I think that I will use a plastic headlight cover, and modify it to fit the opening in the fairing, attaching it to the Alumunum fairing bracket. I'm leaning towards the Graves Fairing Bracket, I'll be using the stock gauges also. I'm assuming that this bracket will mount to the stock bodywork. I know that the stock fairing (brace) will not be needed any longer. Are any of you guys using this Graves Bracket on your machine? This is some of the crazy ideas I have come up with to further this (weight thing). I've taken close to 50 LBS off this TLR, and you know, have spent alot of time money and effort in doing so. It"s become an addiction! I'm in too deep to stop now. And this is a streetbike. I must be crazy, but I love my TL. Any info on the Bracket would be welcome. Thanks TomTags: None
SDTLR, I want to keep the stock Upper and Bodywork, mainly because its nice. And its painted! I think I could come up with something kind of nice on the headlight cover to accent it, like a # plate on the one side, and a screened scoop or air duct on the other side. Are you using the Graves Bracket? Tom
SDTLR are you going to have a headlight in your aftermarket upper?Maybe a projector beam type?"What's it feel like to ride at 200mph"
"It's similar to doing 199mph"
Shinichi Itoh's response to the press when he was the first man to break 200mph on a GP bike.
Go for a look like thisTL1000R -99. Yellow/Black.
picture 2.)TL1000R -99. Yellow/Black.
And, this is how mine looked before the crash...
New fairing is on the way
(I hope...)
EDIT - Yes, it has front lights...
(Those smal holes arent there for cooling...)TL1000R -99. Yellow/Black.
Originally posted by SDTLR
feelin that red one
Johns TLR that is for sale
Here you can drool some more.
All the pictures.
To bad he lives in the artic. Otherwise I would have bought that one instead of the one I have today.TL1000R -99. Yellow/Black.
Forgot, it´s in Swedish...
But, all you need to know is that it has 123 hp at the rear wheel.
MIG carbon fibre slipons. He has the same carbonfibre fairings as me. stock damper.
But you can probably guess what he means, the names should ring a bell.
Still, the Yellow is faster...TL1000R -99. Yellow/Black.
All you see is grins
Damn thats a nice TL.How well does that projector beam work at night?Do you have a link to the MIG web site?"What's it feel like to ride at 200mph"
