6 piston brake upgrade questions for the TLS
I want to put the 6 pot calipers on my TLS. Do I have to get the master cyclinder also or is it just better to? Has anyone used the stock m/c with the 6 pot brakes and then change to the TLR m/c and noticed the difference? I was going to just get ss braided lined and EBC HH pad with my stock brakes but I think I will get the 6 pots, ss lines, and EBC HH pads.Everyone dies but not everyone livesTags: None
Originally posted by scubabiker
You do not HAVE to do anything. They just bolt on. I will tell you though, I have done the mod. myself and I haven't noticed a huge difference. I think that a higher volume master cylinder and SS lines would make a big difference.
I for one thought that going from the stock TLS 4 pots with SS lines to the 6 pots with SS lines and EBC HH+ pads was a HUGE difference. I said it in another post, it is the BEST mod I have made to my TLS so far.
The answer to the actual question is: The big M/C will give you a bit more lever, the smaller M/C has a bit of "sponge" to it no matter how long you bleed the brakes. I am still running the stock M/C so it is usable, just not as rock hard as it could be.
Originally posted by Davcruz
It would be nice to know what you had before the 6 pots, like what pads, SS lines etc so we could compare.
I went from the stock 4 pistons with SS lines and cheap pads to 6 pistons with HH+ pads and the difference was unbelievable. But...to do it right you really need the 5/8 MC to go with the new calipers.
Today my 6 pots just arrived in the mail (yes it is Monday in Japan)
I'm switching to RK 55 gold fine alloy pads...
I'll post how good they feel later...Just a few mods:
I did the same almost. I went from the stock calipers with decent pads and Goodridge lines to the 6 potters with Goodridge racing pads and there was a huge difference. I still use the stock M/c, and I think it works fine for me. I use two finger braking so I'm happy to sacrifice a little more lever travel for better feel.
?? I'm not sure of any one other than the "R", but I'm sure something else must fit.. THe M/C says "5/8" on the back of it instead of the "14" that the stock one uses..
I made the swap from stock-stock to TLR/kevlar/+HH and I love it.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
Originally posted by Stabber
Thanks for the replies. What mastercyclinder will bolt right up to my clipon I know the tlr will but how about the busa one
Im running one on my TLS at the mo and it works a treat but if its looks your after as well as performance the remote resavoir types look best
Dave UK
The older I get the better I was !
<ahref="http://www.wunderground.com/global/stations/03354.html">
<img src="http://banners.wunderground.com/banner/gizmotimetemp_both/language/www/global/stations/03354.gif"
NOTTINGHAM UK
Thanks for the replies. What mastercyclinder will bolt right up to my clipon I know the tlr will but how about the busa oneIt appears that my weewee has been stricken with rigor mortis!
