Do they Make Aftermarket Cams For the TLR?
Help me out guys I need to find out if they make aftermarket cams for the TLR and if so where do I get them.03 Honda RC51
99 Suzuki TL1000R Track Bike
WSMC #642
http://toyride.org
Tags: None
I've never found anybody that has them as a "inventory" item. However, check out Web Cam. http://www.webcamshafts.com/
They will modify you're existing cams. What I did is found a cheap set of cams on Ebay and I'm having those reground so I can keep my other set stock.
Later
Yoshimura also makes them, but I can't remember if its Yosh Japan or Yosh-rd America.Just a few mods:
Re: Do they Make Aftermarket Cams For the TLR?
I'll let you know if they stock them for the TLR and get an estimate for shipping on Monday if I can find out a weight on them.Just a few mods:
Veetwo did make them, and ride height adjusters and piston kits etc, but I reckon to get a set out of them now, you'd need a group buy. http://www.veetwo.com.au"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Spearco....
Made by Spears Company.....I got a set off ebay, they were just installed last week. Not really sure how much difference between degrees and the stock degrees, but I tell you what, they woke the bike right the F#[email protected] up!
the difference between 1/4 throttle and 1/2 throttle is night and day. I'm nto even going to get into WFO....I may not be Mr. Right, but I will have sex with you until he comes along...
The problem is not the cams Its the Cam Sprokets on the cams. The ones from 2001-03 are slotted the part numbers have changed for them. The sprokets are attatched to the cam itself and I have the ones that are not slotted. So I need to get aftermarket or stock 2001-2003 cams.03 Honda RC51
WSMC #642
http://toyride.org
I would consider selling my used set of veetwo cams. They have about 5,000 miles on them. They come with adjustable cam gears. You can e-mail me with at [email protected]
