GREAT passenger seat idea
  • GREAT passenger seat idea
    Okay, I just wanted to know if I am the only one to have ever done this....I mentioned this to my friends and they love it, but have never heard of it. We use to do it all the time in South Africa.
    Here's what you do...
    First, You take the cover off the passenger seat by gently removing the staples that holds it tight.
    Next you cut a groove into the sponge(foam/padding), about 1/2inch wide and 1/2 inch deep and 3" long.
    Next, you cut a 3" piece of your neighbor's garden hose and
    you put this inside the groove you cut into the seat, just nicely to make it flush. Pull the seat cover back over and staple it back underneath.
    Now, you may wonder why I did this - just ask any female passenger, and they will tell you that my ride....IS THE BEST RIDE ....
    "And as I shifted into 6th, I could not remember a word she said..."
    "Talk softly but carry a big stick"
    Cunning, very cunning.
      i dont get it
        Ah!!! a built in puchy vibrater
        red 97 the fast one!
        Mods due to tlplanet;piola damper,ohlins shock/800lb spring,le/racetech forks,ebc rotors and pads,6 pots,Tfi,97 full power ecu,K&N,Airbox mod,Fan switch mod,full yosh with carbon cans,fan mod,topgun undertail ,corbin seat,helibars,top blocks frame sliders and a little of this and a little of that.
          Originally posted by jasonstiller
          i dont get it
          Me either
          Stupidity is like chlorine for the gene pool.......
            hahahahaha...you said puchy!!!
            Full M4 Ti system, Full Airbox Mod w/ TLR bellmouths, Techlusion TFI unit, Stealth 520 17/42,
            SRAD750 6er's, Goodridge SS brake lines, TLR 5/8th MC, Yosh clutch cover, Coerce Sprocket
            cover, 1/5th throttle insert, N2 gap tray, TLR battery relocation, Metz M1's all around
            Jarkott + mod, Barnett Clutch Springs
              you just gotta love the magic of the v-twin's vibrations
              1999 TLR Yellow, Full M4 System, Matt's TRE, Pipercross filter, debating a PCIII.
                I tried that but I inverted the grden hose instead worked much better that way.
                Originally posted by thor
                Freak is from TN....Thus a TOTAL hick, so I will have to honor his oppinion on this as it does pertain to jumping cars over rivers, which his hick status gives him automatic authority and expertise in thus said field.
                like you needed proof lassee was well....
                Originally posted by tl1000lasse
                Thanks guys I can feel the love
                Pappa the backdoor is never closed for you why dont you cum inside it sometimes and thor thanks for all the pretty pics
                  fucking hilarious
                    that's pure genious!
                      Ever heard of the VibeRider?
                      www.leanangle.com
                      Mods - 00-03GSX-R750 forks with race tech valves and springs - 01/02 GSX-R1K calipers - Goodridge SS Lines - Vortex Triple - Harris FA Rearsets - Fabbri DB screen - Kawasaki ZX9R mirrors - Joe V Airbox Mod - PCII - Sparko/Plus Mod - Earthing Mod - K&N Air Filter - SATRE - Kerker Bolt On Pipes - 1/5 Throttle Mod - 17/41 Gearing - Bitubo Shock
                      Current Bikes: 2001 Suzuki TL1000R, 1998 KTM 250 SX
                      Past Bikes: 1997 Katana 600-wrecked | 2000 CBR600F4-Stolen | 2001 GSX-R600-Stolen | 1989 Honda CB1-Sold
                      Why TLP Rules: Free stuff the Planet has hooked me up with: Left side plastic, Stock headers, Tail Hump, K&N filter, Motorcycle Trailer, Misc Nuts and Bolts, Hyperpro Steering Damper
                        No f-ing way I thought this was all a joke.........guess I was wrong
                          you got some issues
                          but i like it
                          MY MODS:
                          TO BE CONTINUED
                            way to go
                            Originally posted by TLCURT
                            Because TL's fucking rock.
                              It would only be worth it if it gets her horny enough to jump on you as soon as the ride is over.
