Leaking gas tank!
  • Leaking gas tank!
    All right here's the deal. I just bought a used gas tank for my 98 TLR as mine was dented. Anyway I installed the in-tank pump and all that, threw it on the bike and poured about a gallon in it to check for leaks.....and sure enough it leaks like a bastard ! SOB!! Anybody have the fuel pump/sending unit crap out of their tanks and have this problem?
    When I put it together I didn't use sealant of any kind because it is a rubber gasket that goes between the tank and the fuel pump. Everything looked to be in great shape. Any ideas?
    Thanks for any advice on the subject.
    Brian
    use permatex gasket rtv (copper) on the gasket. then assemble her again.
      Thanks horkn!
        yeah when i redid mine i put some rtv on it and it hasnt leaked yet....2 years!
          What you want is Permatex #2 non hardening sealant. Is is resistant to gasoline, and most others are not.
            yes thats the copper crapo....
              Also check the gasket sealing surface for rust.
              I AM CANADIAN
                Do the bolts up in a criss cross fashion and don't over-tighten them.
                  Re: Leaking gas tank!
                  Brian
                  Yes I had the same issue Just go to Suzuki and buy another gasket for $20 it solved my problem.
                  03 Honda RC51
                  99 Suzuki TL1000R Track Bike
                  WSMC #642
                  http://toyride.org
                    same thing happened to me dude...
                    tank went away for painting...the $%&kin painter musta hooked it up by the hole where fuel pump went....
                    refitted tank..lost about a gallon all over garage floor..
                    took me about 20minutes with a pair o small grips to re-level the lip...but i also used rtv sealant to be sure this time...
