2 or 4 finger clutch
  • 2 or 4 finger clutch
    Just curious as to how many fingers you use to actuate your clutch. I've always used 4 fingers in order to get it as close to the bar as possible, otherwise it tends to grab a little at complete stops. Lately, though, I've been experimenting with 2 finger actuation at speed. Your thoughts?
    219
    what is this "clutch"
    5.48%
    12
    2
    34.70%
    76
    3
    14.16%
    31
    4
    45.66%
    100
    :dunno I use two on both levers but I find my remaining fingers on the clutch are just sort of over the lever, I dont want to smash my fingers
    I need to find some shorties.
      Maybe I can mill some up
        4 finger attack for me
          four finger leverage for me too!
            4 fingers. Don't think I could pull mine with two fingers for long, and the clutch wouldn't fully disengage with two figers left on the bar, they'd get squashed.
              2 and 3 fingers for me. (even when I had a full lenght lever)
              2 fingers at speed and 3 in 1st gear/slow speed.
              SD, you can get mine slightly modded cluth clever. It┤s a 3 finger max lever now after the crash...
              Probably shawed of a few grams to...
              Got this pracice from dirtbike racing.
              (crashing too...)
              TL1000R -99. Yellow/Black.
              M4 Full system(Alu), K&N Filter, TRE mod, removed Pair valve. Yoshimura clutch cover, removed Scissor gears, Carbon fibre hugger, carbon fibre rearhugger, HammerIt TLR/R fairings, Gilles Toolings rearset. Pazzo racing levers, shorties, Íhlins rear, Brembo front brakes, ET79 undertail, blah blah blah...
                2 fingers for both, adjustments made so that the clutch is fully actuated looonnggg before my other 2 fingers come into play.
                1
                  4 fingers, in case I actually do use the clutch
                  [SIZE=1][B][COLOR=firebrick]
                    4 but have been trying 2 at speed
                      clutch ?
                        atleast at speed/sometimes I've been experimenting
                        "What's it feel like to ride at 200mph"
                        "It's similar to doing 199mph"
                        Shinichi Itoh's response to the press when he was the first man to break 200mph on a GP bike.
                          on the brake lever i use 2 fingers if i really need to stop quick, but usually just 1 finger and not this one . clutch i use 4 fingers at a stop, but 1-2 fingers at speed. kinda weird, but i use 1 finger on the upshifts and 2 fingers on the down shifts
                            4 fingers with my Barnett springs.
                            My new DRZ400 has a clutch that feels like it belongs in a 125. One finger will do. Doesn't slip, but then again, it doesn't make 115 or so horsepower either
                              I also use 1 for braking, unless I have to hammer it. I use 4 for the clutch most of the time...but when I launch, I only use 2. When I already have it in, I slip 2 off to hang onto the bar...'cause we in for a ride!
                              TusherTLR
                              gear:
                              stuff:
                              Joe V mod, Pair valve removal
