wheelie drifting to the right
I've noticed this week that all my wheelies are now drifting to the right.. i checked my rear wheel and it look pretty even... any suggestions.. it used to be always rock solid center on one wheel.. now its a pain in the butt2000 Race only TLR - Accel. Tech built GSXR1K forks w/triple, calipers/pads - Braking Wave Rotors - Full M4 (carbon) - Ohlins damper - Ohlins rear - pirelli tires - Graves fairing stay - Race tail complete with sub-frame - PCII - BMC filter - full Air box mod - Body Double race bodywork - GSXR1K front fender - Galfer/Goodridge lines - Woodcraft rearsets - complete - Woodcraft 50mm clip-ons - Complete front and rear brake levers w/ pazzo short levers red - Tre-Mod + ModTags: None
i'm with Steve on this one............"road crown" is the slight off set slope of the street surface to help water drain off to the side of the road and not puddle up and cause people to hydroplane. it can be pretty dramatic in some places. when i was an automotive tech working on suspension i would set cars up with more positve camber on the left. this would help the car track straight down the road, instead of pulling to the right.
if you ever take a long trip (boring) down the highway on your motorcycle check out the wear pattern on the front and rear tire. the flat area you just created will appear a bit off center.......road crown is the cause of this.........2002 TLR B/W. Yoshimura bolt on Titanium cans. Yosh box remap. Joe V airbox mod. plug in TRE. 17/41 sprockets. Zero Gravity double bubble screen.
Different road with greater camber to your usual wheelie spots?
same roads i've done all summer and its a pretty consistant conciterable difference than before.... and it has seem to come on all of a sudden...Last edited by dsly1; 08-29-2003, 09:01 AM.2000 Race only TLR - Accel. Tech built GSXR1K forks w/triple, calipers/pads - Braking Wave Rotors - Full M4 (carbon) - Ohlins damper - Ohlins rear - pirelli tires - Graves fairing stay - Race tail complete with sub-frame - PCII - BMC filter - full Air box mod - Body Double race bodywork - GSXR1K front fender - Galfer/Goodridge lines - Woodcraft rearsets - complete - Woodcraft 50mm clip-ons - Complete front and rear brake levers w/ pazzo short levers red - Tre-Mod + Mod
Maybe it is due to you bouncin off your back wheel whilest doin zee wheelie hop"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming WOW, what a RIDE!!"
The higher and longer and faster you get those wheelies the bigger your gonads grow, perhaps the right one is heavier than the left one and you need to wait for the left one to catch up :dunno"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
no doubt.. all praise my large testicleserrrrr testicle ....
My 1st gears are way up there now.. and if i miss the shift to second and and not at a balance. I clip the rev limiter and come down...once or twice a wee bit hard2000 Race only TLR - Accel. Tech built GSXR1K forks w/triple, calipers/pads - Braking Wave Rotors - Full M4 (carbon) - Ohlins damper - Ohlins rear - pirelli tires - Graves fairing stay - Race tail complete with sub-frame - PCII - BMC filter - full Air box mod - Body Double race bodywork - GSXR1K front fender - Galfer/Goodridge lines - Woodcraft rearsets - complete - Woodcraft 50mm clip-ons - Complete front and rear brake levers w/ pazzo short levers red - Tre-Mod + Mod
Might make sure that you are not tugging the bars that direction when you start the wheelie. I drift left because I tend to steer the bike toward the center line before I lift it. If I think about it before I start they stay nice and straight. I try to correct the drift by leaning away from it but I normally get nothing. I am practicing stand ups so I can steer it better.
Try carrying your handgun holstered on the left, any diff...
j/k
I notice the same thing tho its always to the left. Sometimes very noticably on the same road. Is your tyre pressure ok, I find mine tend to be straighter with around 36 or so in the back. I used to have a slow leak and I could always tell when it had dropped below 30psi
hmmm tire pressure.. havent checked that in a bit2000 Race only TLR - Accel. Tech built GSXR1K forks w/triple, calipers/pads - Braking Wave Rotors - Full M4 (carbon) - Ohlins damper - Ohlins rear - pirelli tires - Graves fairing stay - Race tail complete with sub-frame - PCII - BMC filter - full Air box mod - Body Double race bodywork - GSXR1K front fender - Galfer/Goodridge lines - Woodcraft rearsets - complete - Woodcraft 50mm clip-ons - Complete front and rear brake levers w/ pazzo short levers red - Tre-Mod + Mod
its ok man, it'll pass i promise. All of my rolling stoppies when i come in at about 70mph tend to fall to the right side at the end. Sometimes its like that for a week or so....sometimes i go through a left side phase. It'll be alright......ooh yeah, P.S. What are you doing 1st gear wheelies for? 3rd is where its at (stand-up) , unless ur 12 o'clock
2001 TL1000R
Carbon Kevlar gsxr1000 solo tail w/ r6 taillights/hammerit tlr/r kit/ full yosh w/ carbon cans/ attack rearsets/ hermit dragon exhaust hangars/Stainless braided brakelines front and back/ EBC HH pads/ BMC race filter/ PC2/ metzler sporttech tires/ carbon here and there/ racelite fairingstay/ Olhins steering damper/ Polished frame, swingarm, subframe................STILL A PILE OF SHIT
"Johnson sprinkle some crack on'em and lets get out of here!"
