average temp
average temp
Just wondering what the average temperature your bike runs at? Mine is about 189 when driving, but the temp climbs pretty quickly if I idle for a little bit. I have heard about the manual switch for the fan, does that help? I hate seeing my temp at 230. Even if it is not bad, it can't be good.'98 TLS with a yellow box and some not-that-new tires.
SE WITags: None
My TLS is about 190 while moving, gets real hot real fast when I stop for a light, it's summer in Houston ya know.
I've done the fan switch mod on mine, and it works ok ... typically I'll switch the fan to on right when I know I'm going to be stopped (either at a light or traffic) and let it run til I'm moving again.
It doesn't stop the temp from rising, but it slows the rise til I can get moving again.
83C - 181Fdouble bubble tinted screen, TLPlanet sticker (5hp), BRAKING rear wave rotor, Busa front calipers (Gold) Ivans TRE, Gixxer rear caliper (gold), Yoshi s/s cans, Galfer front & rear s/s lines, Galfer & EBC pads, Heel guards (magiver), TALON GOLD front & rear sprockets, 520 conversion, RK gold chain, Speedo Healer, Smoken's sliders, Bitubo steering damper, Clear clutch cover,GPI (pedro), Power commander,Tail raise spacers, Bitubo Rear Shock, Rifleman Gap Mod, ET's undertail, ufo tail light, yoyodine led indicators, licence plate holder, Tinted headlight protector, GCC tank protector,
Waiting for: carbon air intake covers, carbon mini hugger
To be fitted:
Race Tech springs, Race Tech Gold valves, Brembo clutch master cylinder,
<a href="http://www.tlplanet.com/subscriber.shtml"><img src="http://tlplanet.com/images/subscriber1.jpg"</img></a>
<a href="http://www.wunderground.com/global/stations/94672.html">
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/94672.gif"
Normal riding: 83C (181F)
Trackday style riding: 86-90C (186-194F)
And I dont even have the fans left... They are unnessesary and frankly, dead weight...
At trafiklights on HOT days,and there a lot of trafik, it sometimes goes up to 100 C (212F), But that is my "record" and have only happened once. The cure was to run between the cars...TL1000R -99. Yellow/Black.
I don't know why they call Japan the "land of the rising sun", because in the summer it feels like that sucker sits at high noon all day...
When you go riding at 0500-0600 and you still feel like a puddle in about 10 minutes; or when you come home at 2400 and you have the same feeling, that's a hot day out
Glad I don't have an "R" like my buddy I ride with, because even my "S" stays about 215-230 in traffic
Its a good thing side lining is legal in Japan; then you just open her up and cool downJust a few mods:
183-185 real consitently on the Highways, even under heavy accelerations. In town at a light, just like everyone else, I can see 200+ real fast.
and
s
189 while riding, and traffic gets it around 196-205 depending on how bad the traffic is. (S model)I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
