Under tail question
  • Under tail question
    How/ what do i have to do to my under tray so i get that nice hole effect above the rear shock like on Jim Brewer bike in the TLOTM
    This part.
    Take the trunk completely out and make your own with some sheet metal. If you don't want to do that just start chopping it up. You will probably have to cop off the whole part where the rectifier sits and make your own or relocate it though.
    Blue and White are Faster
    '01 TLR Formerly B/W
    RIDE SAFE GUYS
      does any one have any pics from anyone who has done this in the past
        check a search on SDTLR...........he pulled that thing out on his way back from the dealership and took pic's too.......
          check the eye candy forum - "undertail options"
          someone has done this :
          i think thats what you need to do
          2000 B/W TL1000R, Full Yosh RS3, K&N, PCII, Homemade fender eliminator, HammerIT airtube covers, fairing mesh...
            Re: Under tail question
            I currently have my (now losing ) TLOTM contestant sprint bike apart. So .. I took the following pictures hoping they might help ... (sorry about the background).
            I had to fabricate a couple of aluminum mounting plates for the ECU, regulator and PCII. The wiring looks like a mess right now since I have it unplugged from the fuel pump, tipover sensor, and generator. It looks better all back together.
            I did quite a bit of cutting on the subframe since I'm only using it for racing .. Let me know if you need better pictures, ok?
              More pics !
              I wanna loose the stocker completely and I´m not sure on how to fit my FSMD and the sheet metal so that I don´t get dirt and stuff in underneath the hump.
                way under
                Does anyone have the step by step install/instructions on how to get the look of the photo posted by speedracer ?
                I bought my bike with an aftermarket undertail that fills in that gap with part of the undertail.
                Its cracked in some spots where it meets the subframe so any ideas would help.
                I know nothing about bikes.
                  All you guys that have done this mod, How many of you have a hugger
                    I do
                      I do too
                        did you guys relocate the rear brake fluid reservoir??
                          I think some have and it might be SD, did away with it all together, just use a sealed capped piece of clear tubing as a reservoir.
                            removed it and plugged the line
                              This is what I did for a rear reservoir and yes, I do use a hugger (most of the time).
