Missing on cold start
I recently rebuilt my TLS after a gearbox failure (Suzuki has superceeded the gear that broke - mustive been weak). Most of the time when I start it up in the mornings it will only run on one cylinder for about 5 seconds - then the other will light up, but miss every now and then, also giving big backfires untill it's semi warmed up. It had new plugs put in it about a month before I stripped it down - any ideas anyoneTags: None
Are both plugs gapped correctly? Are the plug wires pushed in all the way?SOLD! 2002 Suzuki TL1000R -Blue/White
what plugs ya got in there? cr8ek or cr9ek? that and how old is the gas in the tank. i am assuming at least a month.... has it been humid by you? you might want to drain the gas, ans put fresh stuff in. it loses volativity after a while, and also absorbs water...
