exhaust mod?
exhaust mod?
i remember seeing this somewhere, where you cut the weld for the 3 allen screws and remove some baffling. is there a how to on this?Sebimoto Carbonfiber Bodywork, Zero Gravity D/B dark tinted screen, Carbo tech C/F frame guards, C/F look levers, black Spider grips, M4 Full system (alum), PC2, Light tech C/F mirrors, GeeLong C/F tank protector, 520 Conversion W/ Gold RK chain and 16/40 stealth sprockets, Pedros Gear Position Indicator, Fan switch, Airbox lid.....REMOVED, Probolt Fasteners all Gold. Spare Set of AMA's Larry Pegram #72 bodywork, Gold clear clutch cover, Galfer rear wave rotor, Pro-Tek Rearsets, Flycal6 quick release tank and seat pins, in the black frame club, Vandrivers coerce style sprocket guard, and a killer TLR keychainTags: None
anybody?Sebimoto Carbonfiber Bodywork, Zero Gravity D/B dark tinted screen, Carbo tech C/F frame guards, C/F look levers, black Spider grips, M4 Full system (alum), PC2, Light tech C/F mirrors, GeeLong C/F tank protector, 520 Conversion W/ Gold RK chain and 16/40 stealth sprockets, Pedros Gear Position Indicator, Fan switch, Airbox lid.....REMOVED, Probolt Fasteners all Gold. Spare Set of AMA's Larry Pegram #72 bodywork, Gold clear clutch cover, Galfer rear wave rotor, Pro-Tek Rearsets, Flycal6 quick release tank and seat pins, in the black frame club, Vandrivers coerce style sprocket guard, and a killer TLR keychain
Yeah but I wouldnt bother. Stock cans arent cheap, best to keep em that way find a cheap used set or something. I don't know what your cops are like over there but I've been done twice and had to put the stockers back on to have the defect removed. Anyway your right, you take out hte allen head bolt and knock out he baffles with a hammer and a piece of pipe. Dont think they'd sound anywhere as good as the real deal tho.
Save up and buy slipons. If you gt tagged for aftermarket cans you can put the old ones back on.. I still got mine.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
cut the welds on the three allen bolts and remove them..next take a torch(if you're lucky) or a dremel with a small cutting wheel and cut around the protruding pipe about 1 inch,after that cut from inside the pipe about 1 inch deep. Don't insert dremel any further,you start getting into the thicker parts of the baffle and you'll never get it out. When you're done you should have about a 3" opening where there used to be a 1". Make sure you have a ton of those little dremel discs before you start,they break easy.Sounds a lot better than stock and should hold you over until you can get pipes,works for me
oh ok. that conviced me!!!!!Sebimoto Carbonfiber Bodywork, Zero Gravity D/B dark tinted screen, Carbo tech C/F frame guards, C/F look levers, black Spider grips, M4 Full system (alum), PC2, Light tech C/F mirrors, GeeLong C/F tank protector, 520 Conversion W/ Gold RK chain and 16/40 stealth sprockets, Pedros Gear Position Indicator, Fan switch, Airbox lid.....REMOVED, Probolt Fasteners all Gold. Spare Set of AMA's Larry Pegram #72 bodywork, Gold clear clutch cover, Galfer rear wave rotor, Pro-Tek Rearsets, Flycal6 quick release tank and seat pins, in the black frame club, Vandrivers coerce style sprocket guard, and a killer TLR keychain
Originally posted by wazburn
DO NOT DO IT!!!! I had a friend do it and he lost all sorts of power.... Sounds good but no power....
The reason he lost power because there is no back pressure in the exaust it is basicly a straight pipe after that mod.
Dont do it just save your cash and get pipes.03 Honda RC51
99 Suzuki TL1000R Track Bike
WSMC #642
http://toyride.org
DO NOT DO IT!!!! I had a friend do it and he lost all sorts of power.... Sounds good but no power....Everyone dies but not everyone lives
Re: exhaust mod?
I removed the chrome caps and cut the end of the can out, the whole was about 3" in diameter and made a big difference in sound, maybe a little too loud, If you are going to try this i would reccommend Starting with the smallest diameter. It will be easier to cut mor than to add it back.
Kerker Cans, No Cut Frame Sliders, Manual Fan Switch, Tre, EBC Brakes Front and Rear, + Mod, Charging System Mod, Euro Undertail With Led Lights, Led Front Flush Mount Turn Signals, Pazzo Clutch And Brake Levers, 1/5 Throttle Insert, Joe-V Air Box Mod, Michelin Pilot Powers (2CT) Front And Rear.
