M4 full system weight inside!
  • M4 full system weight inside!
    Heres what it weighs--note the empty box wieghs 2 pounds itself. All that is inside the box is the system and one piece of bubble wrap.
    "I might just fade into Bolivion"~Mike Tyson
    so 19.4
    How much does the stock system weigh:dunno
        well, he has yosh race botons... so he can tell you that. i dunno if the tller had the stock cans . but i'm sure somebody does...
          I still have the stock cans and will weigh the full stock system when I get it removed...hopefully later this evening as I am just starting the install
            Go Johnny Go, Go!!!!
            M4's
              The stock cans probably weigh that much each, haha. Those things feel like they're filled with sand.
              Also, is that for a carbon set or aluminum set?
                jenny craig
                I really need to see the difference on these to see the total weight savings. I only have bolt on D&D's.
                I know nothing about bikes.
                  My full yosh system with Ti cans weighed 17 lbs total (including bolts, springs, etc.). Still haven't weighted the original yet...!! I think one can weighted about as much as the full yosh system though!
                      Heres the weight of the full stock system---most of the weight was the cans themselves...they weighed a full 18lbs!...
                      So the full stock system checks in at 28.5lbs versus the full stainless M4 at 19.5lbs
                        FYI the weight of two yosh stailess rs3 race cans
                          And of course the finished product...
                            Install was pretty easy...especially with these ...although lining up the cans was quite the PITA
                              Lucious
