bike running rich
bike running rich
i have a 97 TLS and i have a problem with the bike running rich on me and fouling out the plugs after 1 year. took the power commander off and readjusted the bike and it was perfect for about a year, now black smoke an the plugs fouling out again. any answers out there?Tags: None
Re: bike running rich
Try Iridum ix plugs and see how it runs with them in...Just a few mods:
readjusted how? Yosh box:dunno
Do you have access to a YAFMS box? try zeroing out the ECU. and then redo it. or maybe some hotter plugs/wires:dunnoTLOTM:
Air filter? Dirty? Replace it or clean it if it is a reusable aftermarket one.
Also as usual, #1 on the list, check your TPS.
The black smoke leads me away from a plug problem, although they will keep fouling with a rich mixture."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
That's ironic. My TLS (with PC2) runs like a freakin' raped ape when it is cold out. More air density.
My ported and FMF piped 500cc 2 stroke dirt bike was Godlike in cold weather. Truly sick power. Spin up the rear and wheelie at the same time in 3rd. Yee haw!"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man." - George Bernard Shaw
