TLR C42 issue.
  • TLR C42 issue.
    So this is my headache, I have a 98 tlr it's my first one, so I been rebuilding this bike for about a year, I've replaced the ignition switch due to bad lock I've come to find out that this switch doesn't work with this ecu. Does anyone anything I can do besides paying 200 bucks for a OEM ignition. Thanks
    Welcome to the forum.
    Do a search on the error "c42" and it should find a thread containing the answer.
      I ended up swapping my new cylinder into the old ongition set to keep The OEM plug and wire set up. Worked great for me, was easy.
        the OEM switch has a resistor in it for the ecu .
        you can add a resistor to the aftermarket switch but you need to understand the wiring of the switch.
        If you dont or
        dont have someone who does
        then you need an oem switch
