Just a quick question...
  • Just a quick question...
    Does anyone know if the wheel bearings for the back are the same as the front? Do you think an rf900 bearings/rear wheel would fit?
    Forgot to say, for a 2001 tl1000s.
    Fronts - All Ballz p/n 25-1276
    Rear - All Ballz p/n 25-1039
    cross reference that with what fits on a rf900 for whatever year you happen to have.
    a very quick reference on amazon shows All Balls 25-1269 for the rear of an RF900.
    READY TO LAUNCH
      You already have the answer but to make sure:I have both bikes. No and no.
      History of Q2
      Q1 Build thread
      Q4 build thread
        https://wotid.com/tls/content/view/58/49/
          Slide, Ring and Brainless, many thanks chaps. That checks out with what the guy in the shop said about it matching the Hayabusa. Sorted now, I only asked as there's an rf in bits under my bench. Useless info, an rf900 rear brake lever fits a treat.
            maybe add that to the "compatible parts list database"
            READY TO LAUNCH
              I'll do a search for the list.
              Cheers.
              Last edited by Roundy; 05-06-2018, 06:53 AM. Reason: I had put down that the lever was a bit longer so you get more force and better control. But the reason its longer is when i fell off the original lever snapped off!
