Exhaust gasket
  • Exhaust gasket
    Hey guys i replaced my exhaust gaskets today because i swaped motors. The gasket that conects the small rear header to the main one is a PITA to get in the rear header its extreamely tight. Has anyone else ever had this issue? Unfortuantenly mine kinked in one spot and crushed. I was able to smooth it out and install it after that. Do you think i will have an exhaust leak because of this im hoping i dont have to wait a few weeks on a new gasket because of this.
    As long as it is still in one piece and there is a good portion of surface contact between the gasket and pipes it will be fine.
      And retorque the fastener after a few rides. It will loosen up and eventually you'll have a leak and get to replace the gasket again. Retorquing the new gasket after a few heat cycles seems to fix the problem.
        Thanks alot guys! I wad also wondering how bad is a small ding in a rear header maybe the size of a small finger tip or so?
          Originally posted by Noah 97 tls View Post
          .... I was also wondering how bad is a small ding in a rear header maybe the size of a small finger tip or so?
          You will never notice it from a performance perspective.
            Awesome thanks!
              I torque check mine every 6 months regardless of how much riding I've done. I haven't had to change it since I started doing that.
              READY TO LAUNCH
                I had the same issue until tore my motor down. I found out there were 2 gaskets in the head which pushed the header out further misaligning the pipes messing up the header gasket.
