R1 shock conversion brackets for 97 S
  • R1 shock conversion brackets for 97 S
    Anyone have some of these laying around or know someone that makes them that I can contact? Cheers.
    Where are you located?
    Pala Precision in Ontario, Canada makes nice ones.
      Thats a copy of one of mine. It gives access to the damper screw.
      the ohlins pattern one doesnt
        Located one, thank you fellas. One question though. Do I need to find a reducer for the bottom of the shock? 12mm to 10mm? Read somewhere that I did but haven't seen it mentioned much elsewhere. I'll check the archives again but a straight answer would be great, thanks.
          I need one for a TLR if anybody has one.
          Mods...Pair valve gone,air box mod,Jardine cans,Vanzuki tail risers,charge mod,headlight mod,PCIII USB w/custom maps,custom rearset relocation brackets,GSXR cluster w/JoE's module,Rifleman's 1/5 insert.
