Fuel starvation
  • Fuel starvation
    Hi Guys. First time poster.
    I have a 2000 TL1000R and it starts and runs ok but after running some time especially at highway speeds it loses power. When I pull off and idle down it stalls. After a minute or so it will start again when the idle lever is advanced to the high position. I had a similar problem with a VMax and what I discovered was that the fuel tank was creating a vaccuum as the fuel was used up. When I replaced/cleaned a check valve that fed air into the tank it fixed the problem. My TL seems to be doing the same because when I open the gas cap I can hear the rush of air into the tank. After that it runs fine again for a while until it repeats the problem. Is there a valve in the fuel lines where air can get fed back into the tank to prevent a vaccuum build up?
    Any help is greatly appreciated
    the cap is the vent.
    the air finds its way thru the mechanism somehow.
    clearly yours is not doing that.
    Stripping it and removing any gunk in the mechanism might fix it
      BTW if its an ex california bike it may have a closed venting system different to other bikes . In which case the cap may be a sealed unit
          I will try cleaning the cap with solvent. Hope that works. By the way it is a Canadian bike sold new in Ontario. Here it is mandatory to record the purchase of all licensed vehicles.
          Thanks. I'll let you know how it goes.
          Faith, Hope and Love and the greatest is LOVE
