Please Help!!!! TL1000R
  • Please Help!!!! TL1000R
    I have a 2001 TL1000r. Bike was perfect when i put in storage for winter. Started bike in spring.Put into gear,started loosing gear pretty quick and all gears went to neutral!!! ?? Let bike sit for a few, same thing happens!! Start bike, put in gear and everything goes to neutral. Can someone please tell me what the problem is?? Low Hydrolic fluid maybe?? Please HELP!!!!
    Iíd check 2 things...
    1) the fluid level in the clutch master and make sure thereís no air in it
    2) that the disks and steels havenít stuck together from sitting
    you did not say if the bike was put up properly (stabile in the tank and the whole bit) or not
      the clutch slave has locked itself in the out position. . replace it
        Then bleed...
        and as ring always yells...
        don't tie down the lever!
        ... Listen to Six5 ...
          Wow!! Thanks so much for the quick responses!!! Metalbender, Ring, and Hingle!!! U guys Rule!! Please dont ever leave this site!!! So many people out there can use your help and it is very much appreciated!!!!!! Here in Buffalo nobody at shops are going to help me. They want the Money obviously!!! Sucks.U know what they told me?? Change the oil!!! I had a feeling that wasnt going to work!! I said the engine oil?? they said yes. So i did that and it didnt do a damn thing!! Anyway im not going to argue with anybody!! LOL. I was really hoping not to have to mess with the clutch but if changing and bleeding the hydrolic fluid doesnt work then its clutch time!!! Thanks again!! I will let you all know what happens!!!!
            You are lucky...
            you got some decent people to respond...
            except me, stu, and ray...
            like ring said, replace the slave then bleed, then report back...
              Originally posted by rxf610 View Post
              replace the slave
              Or fix the problem and replace with an S cable system....
                Thatís what I did with my R...of course I did the welded center as well...
                  I changed the slave cylinder. Started trying to bleed the system and the clutch handle went limp lol and wont repressurize!!! Do i now need a new master cylinder
                    Bleed the master first.
                    crack bolt,
                    pull handle,
                    hold,
                    close.
                    repeat until clear fluid runs around banjo bolt...
                    then bleed slave.
                      Thanks Hingle!!! It worked!! Cant believe thats not in manual!?!?!?!? Anyways EVERYONE!! One more time!! UNBELIEvABLE!! Now the bike tried to start, stopped and now nothing at the start button!!! No click. Nothing!! Before i rip into the start button, is there a fuse or anything someone can suggest?? I really dont want to open a can of worms!! lol.PLEASE HELP!! ASAP!!! THANKS AGAIN!!!!
                        Is the fuel pump priming?
                        Sounds like your clutch switch is faulty. Try jumping the wires temporarily, and then hit your start button. If that works then you need a new switch.
                        I live kind of near you in the city of canandaigua. I have an extra brand new clutch switch in the package.
                        2001 TLR.
                        Go back to the Zone, I'm not there, you're not here.
                        No banning of me here, only me stomping your ass here.
                        and now you join an elite group of world champion racers.
                          The fuel pump is priming. I tested the wires and then jumped them with a wire. Is that ok to do? or do i need to pull the coverings back and actually touch the two clips?? lol. Anyways thanks for the idea. I think the starter button is faulty. I just didnt want to take it apart. Want to ride!!! lol. Only other thing i can think of is starter selenoid. I hope thats not it??
                            Jumping the two wires together with a wire is fine.(The bike will remain in cold mapping though) That did not work? Also try shaking the wires on the front left side while hitting the starter.(They over time get pulled apart from poor routing near the forks when the handlebars are turned)
                            If that doesnt work then inspect the solenoid for burn/melting. If it's the starter solenoid then buy a used working OEM one and not chinese junk otherwise you will end up back at square one.
                            2001 TLR.
                              Im at a loss!! I havent checked the solinoid yet but tried everything else!! I ripped into the starter switch and thats good. I will check solinoid next but i will be very surprised if thats it!! Is there a clip or anything i can try and jump start it?? In otherwords Something i can do to bypass everything and here the motor crank over atleast
