Clutch stuff
  • Clutch stuff
    Hey guys my tls seems to shift good but if it's in first gear and I rev it over 6 k or so at a stop light I feel the bike try to pull forward slightly. I have a vanzuki cover and i can see it has a slight movement when this happens. I'm not sure how I would correct this issue or if it is just a matter of replacing the clutch plates and springs.
    Do you have Chinese Levers ?
    And check that your cable is not about to give up on you..
    Check the ends.
      clutch drag is usually warped steel plates they can get dish shaped.
      OR the the thin rings in the bottom of the clutch pack are not assembled correctly and rather than separating the pack keep it closed.
