Yoshimura headers/ diffrent mufflers?
  • Yoshimura headers/ diffrent mufflers?
    My 03 has the Yosh headers with rs-3 slip on mufflers.
    I would love to try a diffrent set of mufflers like a slip on akrapovic ,m4 or even yoshimura dual tip,,
    but am I limited to the diameter of the yosh header?.
    I think it measures 2 1/4 o.d.i prefer to keep the headers and replace mufflers
    any ideas?
    thanks
    Iirc the m4's have the same diameters.
    History of Q2
    Q1 Build thread
    Q4 build thread
      Ok..thank you
        If you cut the 4-bolt flanges off the factory exhaust and weld it on to the Yosh system, your silencer options are greatly expanded.
          I dont have that anymore...wish I did now though..I want to keep the yosh header if I can
            Who else makes a full system?
              I run M4 Headers with 4 bolt Yosh Titanium cans on my TLS.
              M4 can inlets are smaller than Yosh.
              Yosh slip on cans are 58.5 mm inside, M4 are 55 and Akra are 53.
              Akra cans for the Gen 1 Aprilia Mille R are 60mm inlet, of which I have a pair which are carbon fiber if you are interested mint.
              I also have a pair of Akra TL Titanium cans.
              Bill.
                I'm very intrested..
                can u take pictures of titanium ones?
                are they in good condition? Scratches ,dents?
                  Pm me your email and I will forward pictures.
                  The cans are used but in very good shape. No dings or rash.
                  For those following this thread, I can confirm the following.
                  Yosh mid pipe o/d is 57.5 mm
                  M4 mid pipe o/d is 54 mm
                  Akra mid pipe o/d is 52 mm
                  Bill.
                    Pictures sent.
                    Bill.
                        Same here, I have a full M4 system with Yosh bolt-ons. Welding those flanges on affords many options. Considering that used TL OEM headers are often less than $50, it's a cheap add on.
                        You can also use the flange from any other bike's exhaust system. Cans are fairly universal; they have a simple strap around the middle while the exhaust is built such that it lines up with a factory exhaust hangar with said can bolted to it. It doesn't have to be TL specific. Matching up pipe diameters for slip-ons will be more difficult.
                          Thank you for letting me know that..
                          it's going to help
                            M4 SYSTEM & YOSHI CANS 030.JPGM4 SYSTEM & YOSHI CANS 011.JPGM4 SYSTEM & YOSHI CANS 013.JPG
                            Stock exhaust flanges adapted to a M4 system with Yosh Ti cans.
                            When cut where shown, it is possible to separate the two flanges and just use the heavier thicker flange.
                              Heck yaa..thanks
