S v 650 slip on
  • S v 650 slip on
    Any body out there know if the slip on yoshimura full race headers that fit the SUV 650 would work on my tlr 2003 bike?
    I need the slip on rs 3 yosh mufflers but they only sell now for bolt on..I bought my bike from P.o.and it does have the full stainless headers to the rs 3 yosh slip on mufflers problem is my mufflers are damaged and I would like to buy the exact ones new.i know that yosh does sell the slip on rs 3 for the SUV 650 but just not sure if the headers that yosh sells for that bike would work on the tlr . If so I can buy the slip on for that bike and use it on mine..any thought ?
    thanks.
    Pretty sure the SV650 headers will not fit, let alone the SUV 650, whatever that is...
    If you're trying to replace just your slip-ons aka "mufflers" you only get one from the SV650.
    You're better off looking for a Gsxr1000 01-06.
    I had 3 tlrs with gsxr1000 slip-ons. Check my builds in my sig
    History of Q2
    Q1 Build thread
    Q4 build thread
      Lol.
      I meant sv..auto correct caught me...
      and I will check out yours ..thanks
        The p.o. did install the full stainless yosh headers with the yosh rs 3 slip on mufflers.
        yoshimura says they don't build the slip on muffler anymore just bolt on.
        I'm wanting something new that is slip on and that will work with these headers ..might just have to stick with my old cans..who knows..
          Define "damaged." Yoshimura still sells all the separate parts to rebuild the RS-3. You can buy a set of bolt on mufflers (used would be cheaper), then all you'd need are the slip on inlet end with baffle to easily convert them for a full system. There's also a thread on here somewhere about making an adapter to use bolt on mufflers with a full system. Otherwise, Yoshimura sells (as do other manufacturers) any number of other mufflers that will work with their old system, just need to make sure you have the correct diameter inlet for the mids.
          These aren't listed on their web site, you have to call and ask. Helps to have the part numbers. Prices have probably changed by now.
          https://www.tlplanet.com/forum/main-...ura-rs-3-parts
            Just read that link you posted..thank you!.super information..that is what I will do..
              If that doesn't work for you, let me know. I believe I have enough parts in the garage to build two slip on cans with SS sleeves. Everything would be new except the outlet ends, the new sleeves were drilled for the newer square badges (which I have somewhere).
