Well, that wasn't much fun...
  • Well, that wasn't much fun...
    Took the R out to go get a hair cut. On the way back home, it was acting a little funny. It was almost sputtering. The tach died, then the speedo died, and then it really did start sputtering. I was on the freeway and was able to get to my off ramp. As soon as I slowed to a stop, everything went out. No electrics at all. A $72 tow ride home and now it's in the garage. I did check the yellow and clear plugs. No issues there. I suspect it's probably the starter relay. Any other suggestions are also welcomed.
    I'm still trying to figure out why your R needed a hair cut.
      Hahahahahaha!!!!!!
        start at the battery with a voltmeter
        then the fuse box for bad fuses and connections
        then the alternator and rectifier regulator
        then ring someone who can actually sort it
          Ha, smart ass
            $72 tow almost pays for my AAA+ membership with motorcycle and trailer towing.
            ...and the only suggestion I have is to get yourself an S.
              A few other items to check: RR and stator connectors assuming your bike is still OEM. You're on the right track though
              History of Q2
              Q1 Build thread
              Q4 build thread
                  Gee thanks Andy hahahaha....
                    I've swapped out the RR for one of the mosfet units some time ago. I will check those other things as well. Thanks
                      Green plug from the ignition switch. Left me on the roadside in Germany this year till a cable tie came to the rescue.
                        Rick, years ago I suffered a nearly identical situation to yours on my TLR. Only two things differ from your story.
                        1> My R didn't need a haircut.
                        2> I was in a left hand turn lane and not on the freeway when it failed and died.
                        After it was towed home, I found the culprit to be an intermittent connection inside the fuse holder that I had used for the Charging Mod. It was the sort for an ATC type blade fuse. An internal crimped connection had become resistive. This prevented the battery from being charged during operation, so it eventually died as the battery's power was used up. As the battery voltage drops, the instruments begin to act strange, and then eventually there's not enough voltage to support the fuel injection system and the engine dies.
                        Yours could be something similar.
                        The fix, for me, was to replace the ATC fuse holder with a quality unit. I installed an AG fuse and holder - the large glass tube type often found in automotive stereo systems. I encountered the problem during the winter of 2010/2011. Haven't had any issues with it since then.
                        Hopefully you can get yours sorted soon.
                          Tony, if you could, are you able to take some photos of that for me? I can send you my email address. BTW, for all of you, the R didn't need to haircut!! It was me HAHAHAHAHAHAHA!!!!! Although the R does kind of look like it might have a mullet
                            ..... BTW, for all of you, the R didn't need to haircut!! It was me HAHAHAHAHAHAHA!!!!! Although the R does kind of look like it might have a mullet
                            I will send photos. No problem. Just need to find them.
                            I know I have posted them before, either here or on the Zone, but I just couldn't locate the thread.
                              Rick,
                              I found some photos......
                              And I had the date wrong. The failure actually occurred in June of 2010.
                              Anyway.....
                              This is the 'ATC' type of fuse holder that failed.
                              DSCN6581 by Tony Six5, on Flickr
                              After the rubber casing is stripped away.....
                              Here, the pencil is pointing at the failed crimp connection. You can also see the color of the terminal is different because of the heat that was generated due to the poor crimp.
                              DSCN6570 by Tony Six5, on Flickr
                              This is the new AG type fuse.
                              DSCN6569 by Tony Six5, on Flickr
                              And then a size difference comparison .....​​​​​​
                              DSCN6568 by Tony Six5, on Flickr
