Replaced my Chain guide and bike wont go into gear
  • Replaced my Chain guide and bike wont go into gear
    So i removed the clutch pushrod and front sprocket cover
    placed the chain guide in
    replaced the cover and clutch pushrod BUT and here is the stupid part i didnt put the pushrod in first i left it on the clutch assembly
    and tightened it all down
    Now when i try to tighten the bolts the clutch assembly block doesnt tighten down all the way
    AHHHH
    by Clutch assembly i mean the Slave Cylinder..... I also squeezed the Clutch probably 5 or 6 times to try and put it in Gear
      Originally posted by Doolicious_R View Post
      Now when i try to tighten the bolts the clutch assembly block (slave cyl) doesnt tighten down all the way
      Sounds like you are missing the spacer between the slave cylinder and the engine case.
        Is there a small one
        i habe the one on the left
        Its almost like it doesn’t want to tighten down correctly.
        Almost like there is something in the way now
          Fuck me!!!!
          it kept feeling like the right side had something in the way and wouldn’t tighten down so I sprayed all the bolts down
          I sprayed in all of the holes made sure everything was clean
          Tested both bolts and realized I probably had the wrong bolt on the right side but when I checked yesterday the bolt wouldn’t fit into the spacer because it was a little dirty
          I am an idiot
          Last edited by Jeff; 10-07-2019, 10:47 AM. Reason: Fixed the "banghead" for you. No use letting it make you look even dumber. :lol
            Awe
              Alright so everything is back on but she won’t go into gear... I have to assume the clutch needs to be bled
              however upon pulling the clutch lever it’s Very tight. Is that normal
                however upon pulling the clutch lever it's very tight. Is that normal
                Not normal for the lever to be very tight. Especially since you still have the hydraulic clutch. Something is binding or not aligned properly.
                  What would I need to check? I just pulled off the
                  slave cylinder
                  plastic guard for front sprocket
                  pulled the rear wheel to make the chain loose
                    What would I need to check? ......
                    Prior to this exercise, everything worked properly? The transmission shifted okay?
                    Might have the push rod become bent when the slave cylinder was initially not installed properly?
                    When you say it "won't go into gear," is that with the engine running or not?
                    Will it shift into gear with the engine off, and the bike is on a stand, while simply rotating the rear wheel?
                      So since I put the slave cylinder on wrong the first time I think it gave the piston in the slave cylinder room to extend out when I used the clutch to try and go into gear
                      that being said
                      i opened the bladder valve and squished he piston. i closed and tightened the bleed valve and voila all the room that I needed and the bike shifted into gear after all was said and done
                      now to get my mitt-vac and change the fluid
                        So then, apparently the system was pressurized and was keeping the clutch fully disengaged. That's why your lever action was so stiff.
                        Before you call this issue "fixed," inspect the master cylinder pressure release orifice. It may be clogged, or maybe the lever isn't allowing the Piston to retract far enough, thus keeping the vent hole covered. The fluid that you released with the bleed valve should have normally gone back into the reservoir by itself - due to the clutch springs pushing back on the clutch rod and slave cylinder. This should have moved the fluid back upstream and into the reservoir once the lever was released.
                        Last edited by Six5; 10-09-2019, 07:25 AM. Reason: Spelling error - my tablet can't spell. ;)
                          Is there a write up is some sort for that? I’ve had lots of issues with that stupid clutch in the past
                          i have just Over 84000 miles on the bike
