no power to dash or ignition
I have a 99 TLR and its shut off on me recently after I pulled into my driveway (I was riding out in the rain as well). Now when I turn the ignition key to ON, none of the dash lights or headlights come on. If I turn the key to the Park position the back break light comes on as expected though. I tried jumping it and no luck. Im thinking that its an electrical problem, (maybe I blew a fuses somewhere) but I just dont know where to begin diagnosing. Any ideas?Tags: None
Originally posted by gqk7667
pulled the battery cover off and checked the connections there. everything seems ok. this is a newbie question, but how would i go about checking the fuses?
unscrew the little black screw on the top of the fusebox.
Then pull out the fuses and make sure they are not blown,
Have you ever seen a blown fuse
I've never heard of anyone using a smaller battery, that can't be goodTLOTM:
still no power to the bike.
-running with a 12v battery on the bike.
-ive entertained the idea that the ignition kill switch is not working but even then, the dash lights would come on so that cant be it.
-ive checked the fuses are they are all fine.
bike is running stock (power commander is out and stock pipes are on).
-right before it shut off i did smell extra gas in the air but i wasnt sure whether it was from old staled fuel burning off (old fuel had been sitting in the tank for 8 months before it was sold to me)
any other ideas?
i did try jumpstarting it (with a car battery) while the car was running and while it was not running for different voltage output.
i also checked the wire connectors on the left side panel but i wasnt exactly sure what i was checking when i looked on the panel. everything looked fine (nothing looked burned out or no wires looked exposed).
i didnt look under the seat only because i thought the wiring related to the problem would be somewhere in the front (the back light turns on when the key is in the 'park' position)
Still not going since the 7th of September?
Give the bars a good wiggle lock to kock with the battery in and key on and see if the dash lights up. It might be a broken wire in the loom to the ignition switch.
There is more than one supply to the switch, so the fact the parking light comes on doesn't really help except confirm that the battery has some voltage."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
