Wheels question
On eBay, you might even be able to go less than that. As little as possible would be how much I'd tell you to pay
Keep in mind that other wheels might be a direct bolt-on as well. It can increase your chances of getting the wheels cheaper if your search is broader. I think Hayabusa and late-model GSXR wheels will fit the TL? TLR and TLS interchange as well, I think... Someone correct me here if this is wrong!It may be that your sole purpose in life is simply to serve as a bad example.
The Busa's wheels fit. And certain GSXR models. I think it's something up to the K2 range.`99 TLR - 2 into 1 60mm Ti Yoshi headers with custom can, Cams, Flowed, Skimmed, Custom airbox, K&N, Silverline TLRR kit, Motostyle sliders, Powerbronze Double Bubble Screen, Harris Grips, Bitubo rear shock, adjustable rearsets.
o303 gix 1k will fit the front only needs spacers and you have to use the rotors form the tl but the rear is a bolt on cost ya about 400-450 if you search for them.MY MODS:
TO BE CONTINUED
