GSXR forks on TLR or TLS
all the SRAD and new gen gix are teh same showa forks. 600's w/ the standard and 750 w/ the USD. spring rates may vary but other than that and maybe color of preload caps and triples, they're the same.
not including the 1k which is the same stock KYB internal junk the TL's and busas have.AFM #715
Suomy, Leo Vince Exhausts, Stompgrip, Sidi/Motonation, Lockhart Philips, Sonny Engineering, RK Racing Chains, AFAMComment
For the $$ you're talking about in replacement you could send your forks to Traxxion, LE, or RaceTech and have them revalved, rebuilt and custom taylored to your riding style.
Why would you spend the $$ on "stock" peices from some other bike.? Even if it's newer? I don't think the gain is there.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go rideComment
Why would you spend the $$ on "stock" peices from some other bike.? Even if it's newer? I don't think the gain is there.Comment
LE quoted me $400, to rebuild, revalve, respring the front. You can check the others..I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go rideComment
I'm not saying $400 is cheap, just that if you're looking to change triples and forks, then have to change the wheel.. You're changing a ton of things that could affect the handling (geometry). And it's going to still end up costing about that much or more even.
I think you'd be happier with it revalved and setup custom. It was funny that in the new sportrider (not that I think they're the final word), that when they had the suspension on the previous hears model tweaked and setup right, they liked it BETTER than the brand new sytle components on the '03 models.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go rideComment
