http://cgi.ebay.com/ebaymotors/ws/eB...tem=2430934880
anybody tried AGP brake lines from ebay?
You'll have to get some and tell us if they're as good! That set was $65 for front and back which is a good price. The pittings are the compression fittings so it should be pretty good.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
Yep, I have them on my bike. Paid like $75 for the front and the rear. The yellow colored line look kinda queer becaus the yellow sleeving is transparent. The performance is great but the fitment was not that great. One of the front lines is too short to fit in the stock routing clip. They sealed up fine on the first try. For $75 it was worth the minor PITA to install them"I might just fade into Bolivion"~Mike Tyson
Yeah, got them off ebay, came with washer/gaskets and bolts that didnt fit---I ended up reusing the stock washers and bolts...Put the EBCs in at the same time so of course the brakes were much improved...But the lined made the brake lever noticeably firmer"I might just fade into Bolivion"~Mike Tyson
godtilla, you sure you got te same ones?
Just asking because the ad said
"Front Brake Lines: A single line from the master cylinder to each Cylinder, seperately"
And you have it running a stock config..
I would also probably put a little extra heat shrink around the ends of the fittings where the plastic sleeve stpos and the fitting begins. (Less dirt & crap in there that way..)I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
Hmmm, those are the ones that I got...I wonder if I f'ed up routing them and thats why I had trouble. Good Idea on the heat shrink, but would it slide over the fitting and still shrink small enough to seal the line??"I might just fade into Bolivion"~Mike Tyson
Originally posted by godtilla
would it slide over the fitting and still shrink small enough to seal the line??I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
I have the ones from ebay and it came with blue clear tubing around the lines and they shipped fast. I havent installed them yet....anyone wanna help me do that?
2001 TL1000R
Carbon Kevlar gsxr1000 solo tail w/ r6 taillights/hammerit tlr/r kit/ full yosh w/ carbon cans/ attack rearsets/ hermit dragon exhaust hangars/Stainless braided brakelines front and back/ EBC HH pads/ BMC race filter/ PC2/ metzler sporttech tires/ carbon here and there/ racelite fairingstay/ Olhins steering damper/ Polished frame, swingarm, subframe................STILL A PILE OF SHIT
"Johnson sprinkle some crack on'em and lets get out of here!"
Yeah sure will, please send ticket!"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
aaahhh steve, you dont know how much i would love to have the money to do that! You would have a blast here....but it would cost $1500usd for a trip from melbourne to augusta via Air New Zealand.
2001 TL1000R
round trip of course!
2001 TL1000R
