Do you hate the hydrolic clutch on your TLR?
This sum bitch takes more babying then a one year old. Do most of you have a bit of trouble getting a good clean launch on your TLR?.......especially if it's regeared.357Like52.38%187Hate29.69%106other17.93%642001 Suzuki TL1000R:
K&N filter
Yosh. Box (YAFMS)remap
OHLINS damper
+2 AFAM Sprocket
Corbin seat
Bitubo shock
EBC HH Pads
Memphis Shades windscreenTags: None
I ride my TLS with two TLR friends and both of them have converted the hydro clutch to the TLS cable clutch.
Theythe clutch now...
Just a few mods:
ok, on my TLS it seems the clutch cable has strecthed way too much but it's only 1.5 years old....i've adjusted it out all the way at the main adjuster on the engine and it's almost all teh way out at the handle and there still seems to be too much slop? any suggestionsTL1000S - M4 full system, TFi, Airbox mod, TRE, PAIR Valve removal, Galfer SS Lines, TLR 6-pot callipers, Barnett Clutch Springs (not installed), Bitubo (not purchased)
<a href="http://www.tlplanet.com/subscriber.shtml"><img src="http://tlplanet.com/images/subscriber1.jpg"></a>
The manual has the ideal angle of the arm the cable pulls on.
If that doesn't work out, buy a new cable before this one lets you down. (Mine is 4 years old and not a problem with the cable itself, and I keep it lubed.)"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
What he said... mine is the original 1999 part and I keep it clean and lubed
Just a few mods:
is there a write up in the tech section on how to do the swap and what is needed.i know that its been talked about b4, if not it should be like the joe v airbox mod.MY MODS:
TO BE CONTINUED
It doesn't bother me that much. I do have a question though, I just changed my fluid like a month ago annd iit is already "coke" again. Whats up?
Gen. George S. Patton Jr
I too would like to know the reason for Suzuki using a Hydro clutch on the TL's. What benifit does it have? If it was only worse I'm sure they wouldn't have used it.
I for one don't like it. I've had my bike for 6 months and I still stall the bitch when I got my girl on the back and even sometimes with just me on it!
I can't drag race it at the track either. I cant get better then 2.4 sec 60 foot times either.
Honda uses a hydro on the RC51. Maybe its a v-twin thing?
What gives?
Picking up the spooge from the line maybe?
How do you convert HYDRO to a CABLE?
I would LOVE to know."Damn... my brain just stopped"
