ABS weld
I usually weld cracks in ABS with a bigass soldering iron I got from the hardware store (used for soldering guttering I think), and strips of ABS cut off an old airbox I had in the garage... It's worked well for me so far....................Used to ride a '01 TLR
I have heard you can 'weld' fairing plastic with old fairing parts, by dissolving peaces of plastic(same as you are welding) to acetone..
Plastic dissolves and forms sort of glue, when you can glue parts together and the acetone evaporates away and plastic is ok?
not tested this one, probably you can find some instruction from the net
JTI take no liability if someone burns up his/her TL with Jarkko/Sparkko/plus modIt's safe if it's done right....
quote:
Originally posted by tv1000s
Originally posted by BatesTLR1000
I have some glue that the Air Force uses. I'll find out what it is called. And I'll let you know later.
P.S. It works great on plastic.
Isn't ABS glue simply a chemical reaction that essentially melts the plastic together?
Um..... are you actually talking about the fairing bracket itself? Bolts to the headstock (on the frame) and supports the gauges and headlight? I thought that was aluminum?? Maybe different on the ST4 (or are you asking about a different bike?).
True plastic welding involves what is basically a big soldering gun. You prep the crack, then more or less melt the two sides together along with a little bit of filler (old fairing strips work pretty well). When it cools it solidifies back into solid plastic.Nathan
2001 Ducati 996
Former 1997 TLS Owner
Of all manifestations of power, that which most impresses is restraint - Thucydides
I've got a TLS, so I can't say that I've taken an extreme closeup look at the fairing brackets on the TLR. But, on my bike and the others that I've seen, they are made of aluminum not plastic. Am I confused about the part that you are describing? Maybe it's different material on the TLR? If it is aluminum and is mildly cracked, you can probably just find a decent machine/welding shop and ask them if they repair aluminum welds. Should be able to slip the guy a few bucks under the table and have them weld it (assuming the damage is in a repair-able location).Nathan
2001 Ducati 996
To fix up cracks in ABS fairings just use a few drops of MEK (methel-ethel(sp?) keytone) Just spread the crack open a bit, drop a couple drops off of a toothpick or small straw, and press the crack back together for a few minutes. Good as new. Doesn't even seem to harm the paint if you wipe up any spillage quickly.
Done this on a few cracks my fairings had, and they seem as strong as new.
MEK is sold in hardware stores with the paint-thinnner. If you need more body you can dissolve some scrap ABS in some MEK or just buy ABS plumbing cement (same thing).
-Erik
-Erik
Originally posted by HandJuice
Cool. Have you tried this on the inside fairing bracket, the one that the headlight and front cowl bolts to? It seems to be a different type of plastic. I'm gonna try it but I thought I'd ask if anyone else has already.
You might have luck drilling some holes and putting some screws through the broken pieces and some JB Weld to keep everything in place? Again, I think a new one would be the best bet.
-Erik
