Battery leak
Battery leak
Holy crap! I got back from riding on my TLR the other day and noticed a brown liquid substance had leaked out onto my left cowl. I pulled the battery cover and my battery was leaking. It ruined the paint on the left and lower cowl. Approximately $550.00 in new plastic. Fortunately BikeMaster is going to warranty the battery and damage (THANK GOD!). This is the first bike I have seen where the battery is on its side, is this a common problem? When my new plastic comes in I would hate for this to happen again, BikeMaster might not warranty $550.00 in plastic twice. Anyone else had a bad battery? What is a good mfg for batteries for the TLR?Tags: None
Yuasa is generally the best..
But I've thought about checking out Westco also, but haven't taken the time.. (Westco is big in sealed batteries, like in my Miata..)
http://www.westcobattery.com/battery...&vid=1&mid=197
$58 for the battery and the Miata one has lasted me about 4 years. NO problems at all.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
IMPORTANT !!!
When you fill the battery... DO NOT CAP IT right away.
You must let the electrolite be absorbed by the plates.. BEFORE you cap it. This takes 20-40min. You should be no VISIBLE fluid in the battery. Disclamer...PLEASE no NOT use a LIGHTER to check)
This is a problem for those not familure with TL's. Most batteries you can cap rightaway... BUT NOT a TL's!!!
Battery Leak
Originally posted by jupiter33458
IMPORTANT !!!
Battery leak
The battery was about 3 months old, at least that is what the guy said that i bought it from.
I went to the local dealer, told them I bought it there (they didn't even ask for a receipt; that is service) and they agreed that it should be covered by the battery mfg. They just acted as the middle man and had Bike Master warranty the plastic. So they are not out any money. They ordered me new plastic totalling over $550.00 and Bike Masre is flipping the bill! It will be here in 1 week. I just hope that it doesn't happen again, who knows if they will be so kind again.
IMPORTANT !!!
I haven't seen a capped battery in a bike for years.
Whack a voltmeter on it with the bike running, you may have a faulty regulator that is boiling the battery from over voltage / charging."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
Use sealed batteries. I didn't know TL batteries had caps or allowance for fluid to be added :dunno.
Re: Battery Leak
Originally posted by kivmax
So if I buy ia brand new battery from the dealer and they charge it and give it to me ready to install, then they need to cap it correctly. So maybe it is their fault!"Damn... my brain just stopped"
Battery leak
Ok, so if I check the voltage, what should it read while running? I'm not mechanic, but I like to learn all about my bike.
The battery did turn out to be fairly new, I believe they checked the date and it was too new to do what it did. I'm just glad I didn't have to be the original owner to have it covered.
Thanks for the info gents.
Let me know about the voltage, I'll borrow a meter from work.
Jupiter posted this in another thread:
SUZ 7-8
* Remove the service lid and battery cover.
* Start the engine and keep it running a 5k RPM with lighting switch turned on () and dimmer switch turned HI position
Measure the DC voltage between the battery terminaly (+) and (-) with a multi-circuit tester.
* If the tester reads UNDER 13.3v or OVER 14.3v, inspect the generator coil and/or the regulator/rectifier."I spent most of my money on Scotch, women and cigarettes. The rest I just wasted"
