Ronayers Question
  • Ronayers Question
    If I were to order a fairing from Ronayers.com does it come already painted to match the bike? I would assume yes but I don't want a piece of white plastic to show up. Do "OEM" fairing parts come already painted? Is ronayers to best choice online for OEM plastic? Thanks much
    Best advice is to call the source, talk to Chip and tell him Jarrett told you to call. Chip's a great guy and will answer all your questions.
    :thumup
      in the past if there were 2 color choices when i ordered a part, the part numbers were different. the fairings i ordered were painted and even had the decals on them. suzuki may be different so you may want to check before ordering
        Any new "Suzuki" OEM part will be a perfect match including decals. Just make sure right year and right color.....
        Full Yosh - PCII - K&N - Protek rear sets - Joe V mod - Pair Valve removed - Mobil 1 Synthetic - Shaved subframe - BRG 1/5 throttle - Yellow windscreen - Ministalk signals - Hugger - Manual fan switch - TRE - Gap mod with custom tray - GPS - Krisnett spools - Subrame raised 3/4" - 12 volt plug - Rear brake reservoir in tail - M1 Metzlers - Powerlet lead - Extended drain hose - Quick release seat & tank - Top gun undertail with clear lenses - Clock/Thermometer - License plate on swingarm - Belly
          I've ordered oem plastics from RonAyers...they matched perfectly and came with all of the decals on the fairings. "Ready to ride" so to speak. Very nicely shipped to, btw... Good people to deal with, bla bla bla.
          "If you can't solve it otherwise, get violent."
            My cowl was the wrong paint style. The gray strip up the cowl doesn't match. Bothered me at first, but it's fine now. Make sure you have the right part number for your year bike (I checked and I had the right one).
            Pictures
            Here's how it sounds.
              I had the same thing happen-they sent me a different nose piece-if it had just been different decals, I would have been fine with it, but it was a completely different yellow. They were cool about it though and I would recommend them.
