http://www.engineeredracingproducts....sxrridekit.htm
or do you know if this gsxr kit will work, it does look real similar to the upper TLR mount, but I don't know the specs.
Also, I've been hearing about the bitubo rear shock/spring combo. So, the bitubo unit is a direct replacement for the stock spring? and you remove the stock shock (or damper or whatever the correct term is) right? I'm thinking this is the way I would like to go. Thanks for your help....
