Powder coat color
  • Powder coat color
    I just wanted to throw this out there...but can anyone think of a color for powder coat that would go well with my Red TLS? Black is the only color that I can think of...Sorry no pics of my bike at the moment
    Leo Vince F/S? K&N filter PCII Switchable TRE Goodridge SS lines w/ six pots Extreme Graphics Undertail Pyramid Hugger Coerce Sprocket Cover
    Metallic Charcoal Grey.
    Do they make metallic powdercoat?
    TLXR Project Bike:
      Black wheels on a red TLS
        Check with your Powder Coater to see what colors THEY offer.. Otherwise they gotta special order it.. It's not like paint where they can just mix up whatever color under the sun.
        They also have different finishes Gloss, Flat, and even some cool textured finishes. They should have samples you can check out and make your decision on..
        Good luck!
          Ducati's champagne-gold
            how about...
            banana yellow?
              What are the most common finishes used, flat or gloss? I really have no idea...I am just trying to see what is out there...As far as the banana yellow, that might be too much...is there a metallic finish for powdercoating? that might be interesting
