Removing Engine to Powdercoat frame
How easy or hard is it to drop the engine and get the frame powdercoated? I'm hoping to keep the bike and make this a winter project. If it's too much of a pain in the balls, I'll just mask everything off and spray it with Chassis black or the Por15 stuffSOLD! 2002 Suzuki TL1000R -Blue/White
Tags: None
i think its just 6 bolts and 4 wires and it just falls right out..........wait, maybe thats a 1968 VW bug. ask Jim Brewer.......he has the all time record i believe.
How hard is it? Well you basically have to remove every piece off of the bike, including bearings and send the bare frame to the powdercoater. Every piece of your bike will be scattered around the garage until you get the frame back and then you have to hand assemble the bike. Route hoses and wiring, etc. You better have some good tools and the special sockets to remove the engine and swingarm. How hard depends on your skill level, I'm sure some people could disassemble in a day and reassemble in a day a friend wouldn't hurt either. I'm not sure of your skill level though, for instance how long would it take you to swap out an exhaust?
sounds like alot of work, i think you should just go with the other options.imo seeing my brand new bike in 1000 parts dosnt sit too well with me,ima go with the other options.good luck if your gonna dissamble your bike.MY MODS:
TO BE CONTINUED
If it is going to be a "WINTER" project as in it wont be ridden for a few weeks go ahead and remove everything and do it RIGHT!! Its not hard but a little time consuming. You could have the bike stripped to the frame in a day and then back together in another day. Jus ttake your time and take notes on where everything goes. Also very very important get a service manual for torque specs!!!! Have fun and post pics during the project!!! I wish I would have taken more pics while mine was apart!http://media.damnfunnypictures.com/dfp/fg_14.gif
That's on a race prepared TLR, though. A streetbike would be MUCH harder!!MRA Rider Rep; '99, '03, & '05 MRA SuperTwins GTO champ; Big Stick Racing
If you've got a video camera keep it handy. If a picture is worth a thousand word, video is a cool million. Roll tape when ever you're about to disassemble something that doesn't come across as overly intuitive.
Trust me. When I go about tearing the bike down this winter I'm going to tape every minute. Well, not every minute, just the important ones...TLXR Project Bike:
Seems like a lot of winter projects are gonna be happening!
I'm there too...
I have some acid marks on the swingarm and fuel marks on the frame (I crashed it once and prolly the previous owner did so at least once also).
So I'm looking into polishing or coating.
Polishing seems to be even worse, thinking of labour hours.
And expensive, and a lot of extra to maintain afterwards...
I'm prolly just gonna go with the POR-15 or black Chassis stuff which is easier to do myself, cheaper, and requires less maintenance afterwards.
8'm just not sure yet about doing the whole thing inside out, or just the visible parts so that I won't have to disassemble the whole thing.
Prolly, just as a challenge for myself, I'll go for the first option...If You're Not Living On The Edge, You're Taking Up Too Much Space
[SIZE=1][B][COLOR=firebrick]
It appears as though the winter projects are quite similar across the board
But if I am lucky winter won't come this year and we will be riding right through, or maybe not
My buddy stripped his frame down last year and got it all polished without too much trouble so my Tiller should be in good hands for the chassis powdercoating.Galfer braided lines throughout, ATRE, UFO tailight, ET79 Undertail and Hugger, 520 16/39 Gold Chain combo, Full Yosh C/F exhuast, Corbin seat, Ohlins Steering Damper, Ohlins Rear Suspension, Tinted Double Bubble Windscreen, Sylvania Superwhites, Yosh Box Remapped and all protected by GORILLA Alarm System
My skill level is not that great, I feel comfortable changing the oil and filter and removing the fairings, but that's about it. It took me 12 hours to swap out the stock exhaust and put the full M4 on there
Looks like removing the fairings and masking everything off and painting all the visible parts of the frame and swingarm will be the safest choiceSOLD! 2002 Suzuki TL1000R -Blue/White
I would recommend the teardown if you're serious about it. You WILL have to pull everything apart though, and I do mean everything. Rather do it ONCE right then 1/2 ass it and have to do it over.
I've pulled the entire Ninja apart, and it goes back together pretty easy. BUT if you're gonna replace anything get all the parts up FRONT. Waiting for a week or two while a seal or a bearing is on order is a biatch.
And take pics. lots of pics before and after I took pics of the wiring routing, what electrics went where, how the cooling hoses were run.. EVERYTHING..I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
