Yellow and White?
wanna sell themdouble bubble tinted screen, TLPlanet sticker (5hp), BRAKING rear wave rotor, Busa front calipers (Gold) Ivans TRE, Gixxer rear caliper (gold), Yoshi s/s cans, Galfer front & rear s/s lines, Galfer & EBC pads, Heel guards (magiver), TALON GOLD front & rear sprockets, 520 conversion, RK gold chain, Speedo Healer, Smoken's sliders, Bitubo steering damper, Clear clutch cover,GPI (pedro), Power commander,Tail raise spacers, Bitubo Rear Shock, Rifleman Gap Mod, ET's undertail, ufo tail light, yoyodine led indicators, licence plate holder, Tinted headlight protector, GCC tank protector,
Waiting for: carbon air intake covers, carbon mini hugger
To be fitted:
Race Tech springs, Race Tech Gold valves, Brembo clutch master cylinder,
<a href="http://www.tlplanet.com/subscriber.shtml"><img src="http://tlplanet.com/images/subscriber1.jpg"</img></a>
<a href="http://www.wunderground.com/global/stations/94672.html">
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/94672.gif"
damn put them on w/ the white!!Sebimoto Carbonfiber Bodywork, Zero Gravity D/B dark tinted screen, Carbo tech C/F frame guards, C/F look levers, black Spider grips, M4 Full system (alum), PC2, Light tech C/F mirrors, GeeLong C/F tank protector, 520 Conversion W/ Gold RK chain and 16/40 stealth sprockets, Pedros Gear Position Indicator, Fan switch, Airbox lid.....REMOVED, Probolt Fasteners all Gold. Spare Set of AMA's Larry Pegram #72 bodywork, Gold clear clutch cover, Galfer rear wave rotor, Pro-Tek Rearsets, Flycal6 quick release tank and seat pins, in the black frame club, Vandrivers coerce style sprocket guard, and a killer TLR keychain
i say try em on see how we like it get a vote and go from there,im sure what ever you decide it'll work you got good tasteMY MODS:
TO BE CONTINUED
you could paint them hot pink and they would still be seksi (strange...but seksi)
cant harm the bling-a-licious-ness of those wheels
SuperCorsa!!!
I have the same! Absolutely love them.
Tho, mine arent as new and fine as yours...
Im about to switch to the Rennsport RS2 that I have in my garage. The SuperCrorsas are worn out...
BTW - which compaund is it? My SC are SuperSoft.
But completely worn down after 2500 miles (4000km) makes them kind of expensive. Good thing I get them cheap from a few friends that race.
Im not so sure about keeping those Sexy rims white.
White = Innocens, Virginity ...
Black =
Black is the way to go man!
Evil Twin you know, the Dark Side.TL1000R -99. Yellow/Black.
I Photoshoppd a little. OK I was lazy, only front rim, and "so so" quality.
But, do I like the Palomar Beauty in white panties?
Do I like Black.Last edited by PutteLiten; 09-21-2003, 12:31 PM.TL1000R -99. Yellow/Black.
