Hammerit Tail Help
Hammerit Tail Help
I am in the process of installing my new Hammerit TLR-R tail section and need some help. Actually, it's the undertail that's the problem. The tail is bolted in and looks good, but I cannot get that undertail in place. Am I supposed to trim it to fit or something? If anyone has installed one of these things, let me know what the trick is on getting that undertail installed. Thanks...X-TLR owner
05 Black R1, Yosh TRI-Oval Carbon slip-on's, Fender eliminator/mini signals, smoked lenses, Shogun sliders,
And the need, the need for speed....Tags: None
Re: Hammerit Tail Help
The Hammerit TLR/R Undertail.
The undertail is not a straight bolt on like the RR tail.
It is tricky to install.
You need patience and a clear mind, so it's best to do it over a weekend and don't have too many beers while fitting the undertail.
If you're not good with your hands we suggest you get someone to help you, or have a reputable bike shop fit the undertail for you....
...All you need to do is trim the Hammerit Undertail to clear the bungy hook bars on your stock subframe. As we said, the undertail is not a straight bolt on.
Re: Re: Hammerit Tail Help
Originally posted by Wingspan
Straight from Hammerit's web page:
It should read: A lot of bitchin and $%^#$ will go into the fitting of this undertail
Just a few mods:
