Shorter throttle twist?
  • Shorter throttle twist?
    Hey guys, Just got back from Superbike races in Birmingham. Nice to see some TL's out there.... As I was running the back roads on the way up I noticed to get full throttle I really had to twist my wrist to almost my physical limit. Is there a replacement that makes the throttle twist shorter? I have to get a very aggresive grip on the throttle to get WOT.
    Full Yosh - PCII - K&N - Protek rear sets - Joe V mod - Pair Valve removed - Mobil 1 Synthetic - Shaved subframe - BRG 1/5 throttle - Yellow windscreen - Ministalk signals - Hugger - Manual fan switch - TRE - Gap mod with custom tray - GPS - Krisnett spools - Subrame raised 3/4" - 12 volt plug - Rear brake reservoir in tail - M1 Metzlers - Powerlet lead - Extended drain hose - Quick release seat & tank - Top gun undertail with clear lenses - Clock/Thermometer - License plate on swingarm - Belly
    I have heard of a 1/4 twist set up, but don't know much else about it.
    RIP Ron
    Sept. 12 2004
      I have heard of someone getting a 'short throw'...I can't remember who or when...
      TusherTLR
      gear:
      stuff:
      Joe V mod, Pair valve removal
        The factory throttles are 1/4 turn, but years back they weren't, so an aftermarket 1/4 turn throttle was a popular addition to a racebike. There is a 1/5 turn available now though, and a while back I saw someone here had a mod to make your own...not sure who that was though.
        Good luck...
        Jim Miller
        Appalachian Signs & Graphics
        * For All Your Sportbike And Racing Decal Needs *
        Phone: 717-979-2814
        www.appalachian-signs.com
        [email protected]
          Thanks guys... Next time I am turning wrenches i am going to check both ends of the cables to see if there is any room for improvements. It seems like a long time ago I saw an aftermarket set-up that the barrel the cable twist around got thicker as the throttle twisted to give more pull on the cable.
            A cam pulley?
            RIP Ron
            Sept. 12 2004
              Originally posted by GXRKLR
              A cam pulley?
              Not sure what to call it. I guess it would be the difference between twisting a cable around paper towel tube vs the shape of an egg end to end or maybe the lobe on a cam. Following me?
                Here you go:
                  some where I have seen a post on this but cannot remember where anyway supposidly the r6 race kit throttle from Yamaha can be used to replace just the plastic throttle part also some one makes a plastic piece that looks a bit like a horse collar to increase the diameter where the cables ride to give a shorter turn on the throttle. Apparently the Yamaha part is about $25.00
                    Originally posted by Wingspan
                    Here you go:
                    http://www.brgracing.com/
                    Thanks! I'm going to order one now...
                      Can't someone just post the Part # for the Yamaha Throttle or the Suzuki Kit throttle?
                        i have a 1/5 throw. not bad. alot less effort to go WOT
                        AFM #715
                          Does that 1/5 make it harder to make small adjustment to the throttle mid corner or other similar situations. Also, where is the throttle sensor? Since you are opening it up at a quicker ratio would you need to remap?
                          RIP Ron
                          Sept. 12 2004
                            No remap needed.. I double check the TPS though. (It's down by the throttle bodies.)
                            If it opens quicker, yes you are going to have to be MORE sensitive when opening it up in corner.
                              When I was swaping in my new motor I went and adjusted the cabels a bit to shorten the throw. Probably not as much as a 1/5 turn but did tighten the throttle up considerably over stock. The throttle feels a bit more on/off now then it used to.
                              <a href="http://www.streetkore.net"><img src="http://www.sycink.com/images/SKlogoSigpic.jpg" ></a>
                              Cycle World and Salvage
                              (843) 747-2497
