exhaust slider
exhaust slider
Who here would be interested in such a product? The current design is a ring that would clamp to the front exhaust end cap. So it will blend with the lines but be a bit thicker so it will stick out a little and grind down instead of your $400 can. Let me know what you think.RIP Ron
Sept. 12 2004
Tags: None
pretty interesting idea there.............make one up and see how it fits.......what about temperature? what type of material will it be made of?2002 TLR B/W. Yoshimura bolt on Titanium cans. Yosh box remap. Joe V airbox mod. plug in TRE. 17/41 sprockets. Zero Gravity double bubble screen.
that idea is ggrrrrreatSebimoto Carbonfiber Bodywork, Zero Gravity D/B dark tinted screen, Carbo tech C/F frame guards, C/F look levers, black Spider grips, M4 Full system (alum), PC2, Light tech C/F mirrors, GeeLong C/F tank protector, 520 Conversion W/ Gold RK chain and 16/40 stealth sprockets, Pedros Gear Position Indicator, Fan switch, Airbox lid.....REMOVED, Probolt Fasteners all Gold. Spare Set of AMA's Larry Pegram #72 bodywork, Gold clear clutch cover, Galfer rear wave rotor, Pro-Tek Rearsets, Flycal6 quick release tank and seat pins, in the black frame club, Vandrivers coerce style sprocket guard, and a killer TLR keychain
Keep in mind what your cans are made of... you will have to engineer the tolerances and fixturing to the can taking into account for the differences in coefficient of thermal expansion. That way it won't fall off or worse...crimp your cans.
You may even need to make several designs based on what material the can is made of. Therefore you may need to make the slider out of similar material that you are fixturing it to so it doesn't corrode between them.
examples of coefficients of expansion:
Aluminum: .000013 per deg F
stainless steel 304: .0000096 per deg F
Titanium: .0000047 per deg F
You get the idea
I know... I'm an engineering nerd.
Examples of coefficients of expansion:TL1000R: For those who like to drive high speed tanks
well... dissimilar metals... when clamped together.. will corrode eachother..
as far as thermal expansion goes... you'll have to design the slider and do the math to find the tolerances. You are the only one that can answer the "will it leave a mark?" question.TL1000R: For those who like to drive high speed tanks
That guy will be busy, there are so many shapes (diameter) and sizes of exhaust cans for our different bikes....Just a few mods:
