Corbin Seats - Gel Seats
  • Corbin Seats - Gel Seats
    If you have one speak up. Are they really worth the $$$ did they make that much of a difference?
    The gel seat from Suzuki is worth every penny
    Corbin is overpriced...
    Just a few mods:
      i've never ridden with a gel seat, but i have with the corbin. the corbin is quite pricey, but very nice. it's shape is nice because it helps keep your nuts (or nut ) off the tank. it feels a bit hard at first, but is quite comfortable. it also weighs about 3 times more than the stock seat since the frame is made out of metal instead of plastic.
        I have yet to meet a person who has a bad thing to say about the Suzuki gel seat. I am convinced that I need to get one soon. The Heli-bars made a vast improvement.
        Frank
        '97 TL1000S
        '89 VW Golf
          I've got a sargent seat which was custom built with a new atomic foam system I prefer it over the stock seat although it is stiffer at first but will conform to my arse in time check out http://www.sargentcycle.com
            I've got a corbin for my SV that I got off ebay for a buck fiddy. That was the best investment I made for the SV. The corbin seems to conform to your a$$ much more than the stock seat and as mentioned keeps the nuts from gettin' smashed.
              the only thing i didnt like about the corbin i had was the edges were raised so much, that when you hung off, the ridge would ride straight up your crapper
              this was without the piping too
              did you know that you can ride your bike to corbin (in CA) and they will custom make a seat for you on the spot, adjusting it as you like. price is the same and they even ship your old seat home.
              it is an option for you central/northern ca peeps
                Well, I've had both the Gel Seat($119), and the Corbin ($219)on my TLS, and I didn't much care for the Gel Seat. Mine had the cloth cover on it, and I slid around so much it made riding a Pain. I found myself constantly repositioning myself during the ride, and with leather pants on it was 10X worse. I sold the Gel seat on Ebay and got the Corbin. My only Negative comment on the Corbin seat is the firm edges as well, but only because they make it harder to touch the ground when stopped. The weight isn't really an issue for me, as a diet would offset it rather quickly. I found the Corbin helped remove some pressure from my wrists, and once the foam was broken in....................ALL DAY COMFY. To me, the Corbin was well worth the extra 100 beans.
                -Randy
                Whoever said the best things in life are free, obviously never owned a motorcycle.
                  Never had a Corbin on the "S", but the GEL is great.. It does retain heat though on a sunny day..
                  Very comfortable & easy to move around on
                    Got a question.....just bought my Tiller the other day and OMG the pain ! I am def gonna get the gel seat from sazook, but can I get the heli bars or gen-mar riser for it ? If so, which would you recommend and who has got the best deal
                    If you can still hear the sirens behind you, yer not going fast enough
                    TL Mods:
                    ZG Double Bubble, CF levers, Clear lens, 41t rear anodized & hardened, BMC filter, TRE
                    My other rides:
                    '98 Chevy 4.3 S10 stepside
                    '04 Honda Civic Ex
                      I am a corbin on the TLS - It is the best thing in the world.. My only complaint is it lowered the seat height a little bit and I notice it in my legs. But I am 6'1 also.
                        Lowered the seat height eh ? THat would be good for me since I am only five ten and on my toes at the stoplights...
                        Wonder if the sazook gel seat does the same ?
                        Also, I saw a website that sells lowered footpegs that are adjustable (lower for typical cruising or higher for the track or the backroads) but I don't think they make 'em for the tiller.
                        Anyone know anything about this ?
                        TL Mods:
                        My other rides:
                        '04 Honda Civic Ex
                          The Suzuki gel and standard seats look to be exactly the same size...
                          Just a few mods:
                            Thnx that's good 2 know.
                            So no one has any take on the pegs or the risers
                            I'm all cripped up after like 20 mins o ridin !! FOr total comfort I have the VFR, but I'm looking for a happy medium on the Tiller
                            TL Mods:
                            My other rides:
                            '04 Honda Civic Ex
                              Easy way to solve that.... Sell the TLR and get a TLS
                              Just a few mods:
