sick of my TLS
sick of my TLS
my 97 TLS has given me problems since i have owned it. i took the bike in a year ago to get that low rpm surging taken out. they took the pcII off and adjusted everything to factory specs and the bike ran perfect for a year. now the surging at low rpm is back and the bike will not stay started, i have to rev the engine at a light or stop sign to keep it running. i changed the plugs and she ran fine for about a week. mods i have to the bike, i have a full 2 into 1 two brothers sys., k&n filter. i took the pcII off they said that was a problem with the bike running crappy, but i still have it. why is this surging back and why is the bike not idling? what do you guys think out there? thanks for any helpTags: None
have you had the TPS set...
if not do a search on TPS...there are instructions
also maybe a faulty PCII or an inappropriate map ??
there are plenty other things also that i can think of...for example 12 months later starts doin the same stumbling...maybe filter wants cleaniong after 12 months,,
maybe you have had a bad batch of fuel,
just a few things to get you started...
i am sure the oither guys will be along soon with lots of other ideas...probably better than mine
good luck"Sorry Officer ! I thought you wanted to race"
check the TPS setting to make sure its correct and check for any codes..........good luck.2002 TLR B/W. Yoshimura bolt on Titanium cans. Yosh box remap. Joe V airbox mod. plug in TRE. 17/41 sprockets. Zero Gravity double bubble screen.
Re: sick of my TLS
Originally posted by TLX1997
i took the bike in a year ago to get that low rpm surging taken out.2003 Blue and White TL1000R (The faster colors) Yoshimura Ti Cans, TRE, Custom Homemade Fender Eliminator, Hammerit Carbon Look Intake Covers, PC II, Fan Switch Mod. Yellow Box, Nissin Brake Caliper and Goodridge SS Brake Lines.
#1 STUNT FORUM SUPPORTER
Have to agree here. The finest of fine adjustment on the TPS can mean the difference of real crap or real good!
I know it can be frustrating but don't give up the TL is a great bike when running rightRetired the TLR for a Gixxer 1K. Sorry boys I sold you out
jesus christ...looks like i coulda been right.. Wahaey
i think mine wants setting too..i dloaded the video off rupes...butt i think you nee gauges to check..not fully watched it though..the lines bit looks easy enuff....
but i aint got no carburetor gauges :'("Sorry Officer ! I thought you wanted to race"
You're in the Uk.. pickup the morgan carbtune 2.. It's the BEST.. No merury or anything else to spill..
I agree with the guys.. TPS, then set your idle. I'm starting to have the same problem, so a TPS adjustment is in my future too.I've got a huge penis, You've got a huge penis, even Tim over there, yup you guessed it, huge penis. Good, now that that's out of the way, let's go ride
i have just been watching the video a little more...do you have to do a carb sync ??..after setting tps....
mine just ticks over between 11000-12000-11000-12000...
so i figured the tpa was due for adjustment..that is why i dloaded the vid..last night..."Sorry Officer ! I thought you wanted to race"
so i figured the tpa was due for adjustment..that is why i dloaded the vid..last night...<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/global/stations/71627.gif">
Re: sick of my TLS
I've been looking all over Rupes's site for the TPS video with no luck, can someone here kindly point me to the right direction?. Thanks.1999 B/W TLR, Yosh RS Full Exhaust, K&N Filter, Undertail, Zero Gravity Screen, Barnett springs, Tre, Pair Valve Mod.
do a right click ,,,choose save as..on this link....
Tps and other settings mpeg
dont bother if you are on a 56k modem..its 220 mb
good luck..."Sorry Officer ! I thought you wanted to race"
