removeing engine,should i winterize
First of all what special tools do i need, should i winterize the engine before i remove it,and is anyone else out there doing this right now. and should i remove the engine first and then take apart the rest of the bike. oh yea i'm haveing the frame swing arm and other part powder coated. i ask this because i have a friend that says if a motor sits for a mouth or so it clogs up the cyliders or something.Last edited by bikeman; 09-27-2003, 11:51 PM.Tags: None
not sure how you're gonna winterize the motor if she's comming out. winterize would consist of topping off all fluids and or overfilling the oil a bit (from what i've read). i think it would be much eaiser to remove an engine that has been drained of all fluids.once you get it out bag the motor up and keep in a dry place. good luck and make sure to show us some pics of the process
any speacial tools need and where should i start
ok i am going to start removeing parts off the bike.right now i have the pipes and headers off and the radiators,all plastics gauges,subframe and rear brake.now i would like to remove the engine and then swingarm and forks and tires what speacial tools am i going to need.
No special tools needed. Nope if I remember right you have to remove all that stuff!!http://media.damnfunnypictures.com/dfp/fg_14.gif
