It was adjusted almost all the way ta the right and I still had ta get it further ta jump at 1400r's. It was a real sob getting the tps far enough right while snugging it up. Anybody else have this problem? I did do it with thw box & sensors on, maybe that was the problem.
Troubles setting tps
Checked the tps and it wouldn't jump ta the upper bar till 3500r's , so I adjusted it.
It was adjusted almost all the way ta the right and I still had ta get it further ta jump at 1400r's. It was a real sob getting the tps far enough right while snugging it up. Anybody else have this problem? I did do it with thw box & sensors on, maybe that was the problem.Tags: None -
I do mine with everything connected and attached. Even if you have the airbox off you still should have all the sensors connected as the TPS should only be adjusted when the display reads "C00".
It can be a pain to adjust is small movement casues large jumps. But mine isn't at one extreme of its travel :dunno"I spent most of my money on Scotch, women and cigarettes. The rest I just wasted" -
I really don't get your short hand.
Go to the blue message board. Gary has a link to setting it rather easily.I know nothing about bikes.
mine hangs to the left all the time.........ooops, wrong forum2002 TLR B/W. Yoshimura bolt on Titanium cans. Yosh box remap. Joe V airbox mod. plug in TRE. 17/41 sprockets. Zero Gravity double bubble screen.
<img src="http://banners.wunderground.com/bannerComment
Originally posted by dragonbro
mine hangs to the left all the time.........ooops, wrong forumGod put me on this earth to accomplish a certain amount of things. Right now I am so far behind I will never die!
The best gift you can give your children is your time........ride safe
If God didn't want us to eat meat he would have made cows vegetablesComment
Can someone show/explain how I get to this 'blue messge board'? I will be checking my TPS for the first time tonight/tomorrow....
Thanks!Be good, and if you can't be good...be really, REALLY bad!!
TusherTLR
gear:
stuff:
Joe V mod, Pair valve removalComment
link to the 'blue board': http://www.voy.com/14718/
look in the faq's, gary has a good mods/tuning section<font SIZE="5" COLOR="red"><b><center> ~Alien_Tank </center></b></font>
<hr SIZE="10" WIDTH="100%">
-see ya!!!
<BR><marquee BEHAVIOR="scroll" DIRECTION="right" LOOP="25" SCROLLAMOUNT="6" SCROLLDELAY="50"></marquee>
and yes, adjusting the tps to get it set right was easy, you can do it just by lifting the tank and moving a small sensor aside. the only tricky part is re-tightening the screws once adjusted w/o throwing the setting off, just play around with it for awhile until you get the hang of it.
it is very worth doing, it made a huge difference in the smoothness of my bike at low to mid rpms, and it seems to make more power too, no more fumbles or snatchy throttle at 2800k anymore, smooth as butter<font SIZE="5" COLOR="red"><b><center> ~Alien_Tank </center></b></font>
-see ya!!!
thanks dudeBe good, and if you can't be good...be really, REALLY bad!!
TusherTLR
gear:
stuff:
I would really appreciate it if someone can possibly copy and paste Gary's explanation into a Word document (link below)...I can't get to it right now, as this site is rated as 'chat'
my email address is [email protected]
thanks fellas!!Be good, and if you can't be good...be really, REALLY bad!!
TusherTLR
gear:
stuff:
Did you get the memo on the TPS reports? You see we're using the new cover sheets on all the TPS reports now, so if you could just go ahead and remember that next time, that'd be great, m'k?some pics:
http://fotki.com/BIGGY
some flights:
http://myflights.blogspot.comComment
Sorry Biggy...didn't get any memo...don't know about cover sheets...
Was your post in response to something I said?Be good, and if you can't be good...be really, REALLY bad!!
TusherTLR
gear:
stuff:
thanks fellas!!
Is this file too big for anyone to download/send me? Since I can't get to it...I don't know if there are maybe too many pics etc...can someone just have a quick peek?
thanks!Be good, and if you can't be good...be really, REALLY bad!!
TusherTLR
gear:
stuff:
